Really low idle, not sputtering or dying? - JeepForum.com
post #1 of 9 Old 08-05-2012, 09:01 PM Thread Starter
Murdered0utGC
2005 WK
Hey guys , I have a 96 GC Limited with the 5.2 in it, and when I start it up, it starts perfect, but once I start going, whenever I stop at a stop sign or a light, it idles at like maybe 300-400 rpms? the very first line on the tachometer above zero. It NEVER dies, NEVER sputters, idles just perfect. Is this something I should be worried about?
Murdered0utGC is offline
post #2 of 9 Old 08-06-2012, 02:33 AM
plafranx
Try cleaning your idle air controller (IAC) and throttlebody. Mine Idles perfectly now.
Let's bust a nut
plafranx is offline
post #3 of 9 Old 08-06-2012, 02:58 AM
Grand_ZJ
^ I agree. Usually a low idle problem is a case of a dirty TB.
Grand_ZJ is offline
post #4 of 9 Old 08-06-2012, 09:17 AM
iser
seafoam. i am a believer.
- REST IN PEACE, RATMONKEY -
Specs- 97 ZJ 5.2L - 4" Zone Lift - 285/75R16 Cooper STT
Upcoming Projects- Front Axle Swap. On the look out for HP30.
_______________________________________________
"lead me, follow me or get the hell out of my way"
- gen. george patton
iser is offline
post #5 of 9 Old 08-06-2012, 09:34 PM Thread Starter
Murdered0utGC
2005 WK
Thanks for the responses guys, Ill get to it tomorrow and let you know how it goes!
post #6 of 9 Old 08-07-2012, 01:13 AM
plafranx
^ Agreed. Since you're seafoaming, might as well put some in the crankcase and change your oil afterwards. I use an aerosol bottle on the throttlebody for ease.
FYI You need a T-20 (Torx bit #20) socket to remove your IAC.
Hope it solves your problem so you can move on to the next of hundreds.
Let's bust a nut
plafranx is offline
post #7 of 9 Old 08-31-2012, 08:07 PM Thread Starter
Murdered0utGC
2005 WK
Just an update, I used the Aerosol seafoam and it worked like a charm! I am now a seafoam believer, hasn't died on me since! thanks for the help guys!
post #8 of 9 Old 09-02-2012, 11:44 AM
Darman
mine idles around there. i clean the IAC and seafoamed. still idles there just fine. if i let off the brakes a little bit itll start to shutter forward. like i can feel every piston firing.
Darman is offline
post #9 of 9 Old 09-03-2012, 03:58 PM
Myusername1674
Mine idles really low to, in park at around 500, and stopped in drive around 200-300. I need to do a tune up soon, never cleaned my IAC but have seafoamed through the brake hose line. Maybe I'll seafoam again just everywhere
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
idle , low
3.7 sputtering/stalling at stop, occassional surge at idle meep WK Grand Cherokee & XK Commander Forum 11 06-11-2012 01:32 PM
Bucking, Sputtering, Wierd idle IAC motor, TPS, Im stumped?? jlcca844 ZJ Grand Cherokee Forum 42 09-30-2011 05:36 PM
Car Dying at Idle? 96jeepman ZJ Grand Cherokee Forum 7 11-27-2010 09:04 AM
rough idle and sputtering MAjeepkid ZJ Grand Cherokee Forum 2 06-25-2010 09:24 AM
Low Idle/Dying When Not In Gear tb123 ZJ Grand Cherokee Forum 4 02-23-2009 10:23 PM
