-   -   Really low idle, not sputtering or dying? (http://www.jeepforum.com/forum/f13/really-low-idle-not-sputtering-dying-1401864/)
Murdered0utGC 08-05-2012 08:01 PM
Hey guys , I have a 96 GC Limited with the 5.2 in it, and when I start it up, it starts perfect, but once I start going, whenever I stop at a stop sign or a light, it idles at like maybe 300-400 rpms? the very first line on the tachometer above zero. It NEVER dies, NEVER sputters, idles just perfect. Is this something I should be worried about?
plafranx 08-06-2012 01:33 AM
Try cleaning your idle air controller (IAC) and throttlebody. Mine Idles perfectly now.
Grand_ZJ 08-06-2012 01:58 AM
^ I agree. Usually a low idle problem is a case of a dirty TB.
iser 08-06-2012 08:17 AM
seafoam. i am a believer.
Murdered0utGC 08-06-2012 08:34 PM
Thanks for the responses guys, Ill get to it tomorrow and let you know how it goes!
plafranx 08-07-2012 12:13 AM
^ Agreed. Since you're seafoaming, might as well put some in the crankcase and change your oil afterwards. I use an aerosol bottle on the throttlebody for ease.
FYI You need a T-20 (Torx bit #20) socket to remove your IAC.
Hope it solves your problem so you can move on to the next of hundreds.
:2thumbsup:
Murdered0utGC 08-31-2012 07:07 PM
Just an update, I used the Aerosol seafoam and it worked like a charm! I am now a seafoam believer, hasn't died on me since! thanks for the help guys!
Darman 09-02-2012 10:44 AM
mine idles around there. i clean the IAC and seafoamed. still idles there just fine. if i let off the brakes a little bit itll start to shutter forward. like i can feel every piston firing.
Myusername1674 09-03-2012 02:58 PM
Mine idles really low to, in park at around 500, and stopped in drive around 200-300. I need to do a tune up soon, never cleaned my IAC but have seafoamed through the brake hose line. Maybe I'll seafoam again just everywhere :thumbsup:
The time now is 07:47 PM.
