Real head scratcher - JeepForum.com
post #1 of 18 Old 02-25-2009, 06:32 PM Thread Starter
NEVADAGARY
Real head scratcher
Hi all,
I'm new here, my name is Gary and I'm ZIPGRAVER on Reno4X4.com. I have a 98 Grand Cherokee Limited and I have an unusual problem that I posted on Reno 4X4 but nobody could help me with. Maybe someone here had this happen to their GC and can give me a hand. The tailgate is stuck closed and it seems the handle won't operate the latch. Someone did say there is a chintzy plastic clip that holds the handle to the latch rod and it might be broken. I tried removing the trim panel but that can't be done with the tailgate in the closed position. Question...is there any way to get to the latch operating rob without destroying the the trim panels inside? The tailgate window operates electrically but I don't think the tailgate does.
I'd sure like to get the tailgate open.
Thanks
Gary D.
NEVADAGARY is offline
post #2 of 18 Old 02-25-2009, 06:39 PM
SET2JET
do you have a buddy with a ZJ? so you can take off his and see how it works... that is what it did when mine did that i could see how it worked and measured his to mine and drilled an 1/8" hole so i could get a small screwdriver in there and pop open the latch and then repaired mine also with the hole being there if it happens again... well you know
also try to seach this is a common prob.
SET2JET is offline
post #3 of 18 Old 02-25-2009, 07:07 PM Thread Starter
NEVADAGARY
Duhhhh. I have one sitting in the street right here. Duuhhhh. Thanks! Brain clouds are serious sometimes.
post #4 of 18 Old 02-25-2009, 07:26 PM
Country Boy
Bovi-sapiens
Country Boy's Avatar
Try pushing against the tailgate like if you were going to close it farther. Then try the latch. My 97 used to do that from time to time. You'll need to lubricate the latch, then adjust the mechanism. You'll have to remove the inside panel to get to the adjustment.
2000 WJ Grand Cherokee Limited, 4.7l V8, Quadra-drive
Farming is easy when your plow is a pencil and you are a thousand miles from the cornfield. -Dwight D. Eisenhower
Don't curse the farmer with your mouth full.
Ah, cows. A thousand roast beef sandwiches wrapped in a gorgeous leather coat.
Country Boy is offline
post #5 of 18 Old 02-25-2009, 07:31 PM
-cAcHe-
-cAcHe-'s Avatar
see that threaded rod on the right?
that is what you have to pull to get the latch open... I KNOW I KNOW...your asking how???
you will have to cut on top where the carpet is on the inside of the tailgate..enough to get your arm in there and pull that rod...then it will pop open..then take off all the screws and weld or jb weld the rod to the mechanisim it is attached to..thats what i did!
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline
post #6 of 18 Old 02-25-2009, 10:21 PM Thread Starter
NEVADAGARY
Tried that a hundred times. No luck
post #7 of 18 Old 02-25-2009, 10:22 PM Thread Starter
NEVADAGARY
Awesome pic and instrutions. Thanks! I'll do it.
post #8 of 18 Old 02-25-2009, 10:24 PM
ddeadserious
x2 on cache96.
Except you don't need to do any cutting necessarily. I was able to undo all the screws from the inside, get the flipper window open, and shove my arm(with a set of vice grips) down there, clamped on the rod, and pulled up really hard. Did'nt do any damage and haven't had any problems since I got it properly adjusted.
1998 White ZJ Laredo: 5.2/242 // d30/d44a // BB // MX6's // Black Steelies // 30x9.50x15 BFG A/T's // FM50 // JCR T-Case Skid // Leather and stuff
ddeadserious is offline
post #9 of 18 Old 02-25-2009, 10:27 PM
-cAcHe-
-cAcHe-'s Avatar
no problem..just make sure you do a slit on top of that carpet..dont go cutting up the entire cover..hahahah...it is kinda hard to get through but take your time..
-cAcHe- is offline
post #10 of 18 Old 02-26-2009, 03:16 PM Thread Starter
NEVADAGARY
Originally Posted by ddeadserious View Post
x2 on cache96.
Well I removed all the screws (4) that I could find and there is NO WAY I can get anything down between the trim panel and the door frame. Can't even see down there. Maybe yours is different?
post #11 of 18 Old 02-26-2009, 03:17 PM Thread Starter
NEVADAGARY
Yep I see exactly what you're talking about. Thanks!
post #12 of 18 Old 02-27-2009, 11:54 AM Thread Starter
NEVADAGARY
Glory be!!! I was looking at the tailgate this morning and I decided to give it one more try before I started cutting. So I pulled the handle and pushed in and UP at the same time an the thing popped open. Huh! The guy that owned it before me told me he had about 500 pounds of snow fall on it when it was open and it snapped the ball ends off both lift cylinders. Maybe that caused the tailgate to drop or ??? He said the tailgate fell on his head.teehee:
I have two cylinders to put on and I will remove the trim panels before I close it again to adjust the latch.
Gary D.
Old but having fun
Real Americans drive Real American!
post #13 of 18 Old 02-27-2009, 11:56 AM
-cAcHe-
-cAcHe-'s Avatar
NICE!! lol..i had the latch fall on my head..hurt like hell...replace those and check the adjuster and everything should be fine.
-cAcHe- is offline
post #14 of 18 Old 02-27-2009, 11:56 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
I'd use an entire big can of WD40 on the latch assembly.
HighLonesome is offline
post #15 of 18 Old 02-27-2009, 03:50 PM
Shinobi
AHHHHHHHHHHHHHHHHHHH WAZZZZZUP !!! its ur friendly neighbor shinobi
Shinobi is offline
4.7l oill fill spout gunk! Head Gasket? Cracked Head? kc8ztw ZJ Grand Cherokee Forum 10 10-29-2009 10:49 AM
Will a cracked head or head gasket...... jpl ZJ Grand Cherokee Forum 2 03-04-2009 08:35 AM
Going head to head with these specs which jeep will perform better offroad, keeth1123 ZJ Grand Cherokee Forum 6 03-02-2007 08:23 PM
Is this for real? Test ZJ Grand Cherokee Forum 3 05-17-2006 09:17 PM
Will the real VIN please stand up rickd. ZJ Grand Cherokee Forum 7 02-06-2006 11:06 AM
