Ready for another question??? - JeepForum.com
post #1 of 3 Old 01-28-2013, 03:06 PM Thread Starter
Graymac
I am trying to figure out as much as I can with this zj. I am the type that has to have all the info I can. Planning on changing all fluids as I have no idea when the previous owners have done so. My dilemma. Haynes manual leaves a lot of blanks to be filled.
I have determined the transfer case is indeed 249.( Quadra - trac ) I assume
However the plates on the differentials tell me nothing as in the manual they list models 35, 194, 216, 198, and 216.
How do I determine which model is under my feet right now?
Front is the same. Numbers don't jive.
I know this is an easy answer for seasoned jeep vets, unfortunately I am just beginning this adventure.
Graymac is offline
post #2 of 3 Old 01-28-2013, 03:10 PM
JohnnyZJ
95?
rears a D35, fronts a D30.
if you have all wheel drive you've got the np 249 correct.
you can use regular 80w90 in the diffs. and ATF3 or better in transfer case.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #3 of 3 Old 01-29-2013, 08:04 AM Thread Starter
Graymac
Thank you kindly. It was driving me nuts last night.
Graymac is offline
