ready for 8.8..what would/did you do? - Page 3 - JeepForum.com
post #31 of 36 Old 06-26-2013, 04:49 AM Thread Starter
srieger
Thanks alot guys! Im thinking of starting with a open carrier just incase i want to lock it eventually, ive found a couple 8's with lsd's but if its going to be a pain down the road to lock it, and the stock lsd is garbage i dont see the benefit. Ive actually started reading in random google searches that the lp d30 is actually decently strong even with a lunchbox in it. Any thoughts? Is it worth a hp swap or will the lp hold up? Very rarely do i actually need to throw it in 4wheel. And when i have to i normally just have to apply a little pressure on the gas to pull myself up or out. Being my dd at the moment i try to avoid damaging things if i can help it lol
srieger is offline
post #32 of 36 Old 06-26-2013, 06:23 AM
speedbucket
I wouldn't swap in a hp30 just to swap it. If you have to regear or break a lp 30 then replace with a HP....
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #33 of 36 Old 06-26-2013, 08:29 AM
JakeC132
When i got mine i welded the tubes the same time i welded the artec truss on. Truss is awesome. I re-geared to 4.56 and threw in a locker. Since i was re-gearing i changed all the bearings and seals while i was in there. Brakes were cheap enough. Got calipers, rotors, and pads for $110!!
JakeC132 is offline
post #34 of 36 Old 06-28-2013, 12:33 AM Thread Starter
srieger
Ok so thinking of just keeping the hp30 for backup and just swapping the 8.8 in since like i said i rarely use 4wheel. This way i have a strong dependable main drive axle and if something happens to go on the lp30 i have a upgrade on hand.
srieger is offline
post #35 of 36 Old 06-28-2013, 03:39 PM
kg6mov
Hears the voices
kg6mov's Avatar
Wheel it till you break it, weld it back together, repeat.
kg6mov is online now
post #36 of 36 Old 06-28-2013, 09:35 PM Thread Starter
srieger
I like your motto lol its probably whats going to end up happening lol
srieger is offline
