Read axle problems - JeepForum.com
post #1 of 4 Old 07-28-2009, 08:01 PM Thread Starter
abe51
Read axle problems
My jeep has 150,000 miles on it now. The rear end is starting to make noise.I not sure how much longer it will last.Can anyone tell me what axles will trade out to replace it with. Someone told me I could use a Ford axle.Can anyone give me advise on what will work. Thank you
abe51 is offline
post #2 of 4 Old 07-28-2009, 08:20 PM
sadass
Try the XJ section for a better response. You are in the ZJ WJ tech section.
5NineZJ,35mtr/k IRO 7" LA F/R Detroit F/HP-4.56 R/Aussie 44A. ARB Snorkel/JRC Sliders/ Protofab w/9500S./Bushwhackers. Novak242 TCcable.
sadass is offline
post #3 of 4 Old 07-28-2009, 08:26 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
You can open the differential by removing the cover and looking inside. It could also be in need of oil. remove the oil plug (plastic or threaded) and stick your finger inside and down to feel if it has oil in it. Sometimes the oil seals wear-out and leak out all the oil, then make noise.
As for the Ford axle the most common swap for that is a 8.8 or 9.0 depending on the size of you vehicle. One should have some technical knowledge for this swap though. You can also try finding a replacement axle at your local junkyard.
P.S. Welcome to Jeepforum
Group W Bench
CRAWLING 98 is offline
post #4 of 4 Old 07-28-2009, 08:47 PM
gatorayde
Guessing that you have a 2000 WJ, an 8.8/9" are not what you want for your situation. Almost any rear axle behind a 4.0 WJ will swap in (just be sure it's a dana 35, there is a small percentage that had d44a's behind the 4.0 with the tow package but it's very rare). Also make sure it's the same gear ratio. If you are going to be going ~33" tires or bigger in the future, a d44a from any V8 WJ will swap in very easily, the only modification you need to make is to shorten the driveshaft (and re-gear the front axle if you don't have 3.73's already).
gatorayde is offline
You guys with heater/heat Problems (READ) midnghtshdow ZJ Grand Cherokee Forum 8 12-19-2009 07:01 PM
Problems with Battery, Alternator, Starting Erroneous Codes? Read This! StillinSaigon ZJ Grand Cherokee Forum 0 07-07-2009 11:11 AM
axle ? how do u read tag ttavenieriii ZJ Grand Cherokee Forum 25 11-20-2008 10:06 PM
left rear tail light problems. PLEASE READ FOR THE DESCRIPTION. may be a simple fix PJNovinskee27 ZJ Grand Cherokee Forum 3 10-01-2008 10:09 PM
Fuel Problems Please READ!!!!!!!!!! Jay1982 ZJ Grand Cherokee Forum 6 08-05-2006 11:48 AM
