RE shocks - JeepForum.com
post #1 of 10 Old 06-22-2009, 06:08 AM Thread Starter
mbquart
RE shocks
When installing these on a 96 ZJ the rubber boot will be up on all four corners, does this sound right?
mbquart is offline
post #2 of 10 Old 06-22-2009, 06:17 AM
Virmagicus
Virmagicus's Avatar
Depends on what type of shock they are. Which RE did you buy ?
Jeff
Virmagicus is offline
post #3 of 10 Old 06-22-2009, 06:21 AM Thread Starter
mbquart
They are meant for a 4'' lift and say they are extreme duty monotubes.
mbquart is offline
post #4 of 10 Old 06-22-2009, 06:26 AM
Virmagicus
Virmagicus's Avatar
Monotubes can be flipped either way...does not matter. The RE Mono's are designed to be ran with the boots down on our ZJ's. I run the RE monotubes as well.
Jeff
post #5 of 10 Old 06-22-2009, 06:53 AM Thread Starter
mbquart
I was told their are drain holes that if ran upside down will void the warranty. So all four corners are with the boots down? Is this the same for all ZJ's?
mbquart is offline
post #6 of 10 Old 06-22-2009, 10:37 AM Thread Starter
mbquart
The old RC shocks on it now have the sliding end up?
mbquart is offline
post #7 of 10 Old 06-22-2009, 10:53 AM
WJ04
I have RE monotubes on my 4'' lift WJ and all four are boot down tube up
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #8 of 10 Old 06-22-2009, 10:57 AM Thread Starter
mbquart
All right I will mount them with the boot down, it looks like you only have a choice in the rear to go the other way. Everyone enjoy these shocks?
mbquart is offline
post #9 of 10 Old 06-22-2009, 11:59 AM
Virmagicus
Virmagicus's Avatar
They are a bit stiff at first but do eliminate alot of body roll .
Jeff
post #10 of 10 Old 06-22-2009, 03:16 PM
WJ04
LOL...yeah I like a stiff ride and I remember the the first thing I said when I tested them out. wow these are stiffer than I thought but in a week or so they were perfect.
Some of my videos:
WJ04 is offline
WJ: Cheapest shocks for 4" lift, What OEM Monroe shocks fit? iluvtruenos ZJ Grand Cherokee Forum 6 06-29-2009 01:05 AM
Fox 2.0 Emulsion shocks for wj ?Doetsch tech 8000 prerunner shocks ? genislav ronen ZJ Grand Cherokee Forum 2 06-04-2008 09:31 PM
Doetsch Tech DT3 Shocks vs. Rusty's Performance Shocks ColoradoJeepin ZJ Grand Cherokee Forum 0 05-07-2005 03:24 PM
Shocks???? seggerty ZJ Grand Cherokee Forum 2 04-16-2005 08:39 PM
Air Shocks for -04 (not bags, not a leaf, not spacers, not lifts - but air shocks) Mike_W_04 ZJ Grand Cherokee Forum 1 02-19-2005 01:36 PM
