RE rear top shock metal fitting - JeepForum.com
post #1 of 3 Old 09-29-2005, 11:24 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
I have the RE shocks from kevins 2.5" BB kit and his site mentions that the Dostech shocks require making a new metal fitting because it is too big but mentions nothing of the RE shocks being too small. Anyone else have similar experiences and what did you use to fix it?
Was just going to grab any pipe and cut it to fit from home depot (equivelant). I wish his stupid instructions mentioned this so I could have had this finished tonight...ARGH.
Oh well, have the BB installed and everything done except the rear shocks.
-Ryan
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #2 of 3 Old 09-30-2005, 04:38 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Ryan,
call Kevin's and see if he can help.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #3 of 3 Old 09-30-2005, 02:17 PM Thread Starter
ArloGuthroJeep
Mr. Hyde!
Went to two local hardware store, checker, and napa and none had anything that could work for the sleeve. Finally went to Johns 4x4 (local 4x4 shop...) and they let me root through an old parts bin, found a couple that were long and they cut them for free
Kevin finally called back and his solution was to put 1/2" washers (one on each side of the bushing) to keep it in place. Wish he would have mentioned that earlier or in the online directions etc...
Either way now I know and so do you
EDIT: Kevin said he is currently in the process of making a new metal sleeve.
-Ryan
Right Rear axle Bearing not fitting markakapops ZJ Grand Cherokee Forum 1 01-23-2010 01:09 PM
WJ with horrible metal on metal suspension sounds Clockwork15 ZJ Grand Cherokee Forum 2 01-24-2009 03:05 PM
metal squeaking on metal? sound from front Dillonzj ZJ Grand Cherokee Forum 3 11-28-2008 12:08 AM
Leaking rear break line, fitting removal? ZJcrawler45 ZJ Grand Cherokee Forum 10 08-28-2008 01:58 PM
metal on metal sound in rear brammabull69 ZJ Grand Cherokee Forum 7 05-21-2007 10:05 PM
