RE 3.5" lift only 2.75" net lift??? - Page 3 - JeepForum.com
post #31 of 71 Old 06-27-2013, 10:30 PM Thread Starter
hondakilla98
Originally Posted by WhiteOut View Post
This was a 3.5" RE kit with a 0.75" spacer in the rear and a 1.25" spacer in the front. ARB and a Warn M8000
That looks good, did you have any issues or complaints about that setup? What size tires are you running?
5.9 Limited, RE 4" lift, RE FTB, JK take offs w/ 255/75/17 BFG MT's, 1.25" wheel adapters, ARB Bumper, Superwinch LP10000, K&N intake, Flowmaster, custom JL & Focal stereo, 20% tint, KOR roof mount tire carrier, JCR sliders, cobra 75 wx st
hondakilla98 is offline
post #32 of 71 Old 06-27-2013, 10:45 PM
dnuccio
what i said made sense in my head, i dont know how to explain it
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #33 of 71 Old 06-28-2013, 12:11 AM Thread Starter
hondakilla98
I've been there before.
post #34 of 71 Old 06-28-2013, 02:45 AM Thread Starter
hondakilla98
If I put a 1.75" spacer up front, a .75" in the back and install a winch I should be just under 4" front and rear. I'll also install an adjustable track bar up front. Is there anything else I should change while I'm at it? Maybe an OME steering stabilizer? Are my RE lower control arms and stock uppers going to be ok. I'm assuming I should install the winch and front spacers at the same time so I'm not sitting at 4.5" lift up front? I'm hoping to avoid death wobble.
post #35 of 71 Old 06-28-2013, 04:18 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
New springs won't be better? Uh, you want new springs because they will not already have settled to what looks like much less than 3.5 of lift. My 4.5 springs with the Arb didn't settle that much. The spacer is a cheaper way to fix that but, if you sag / settle any further with the winch, you don't want to add yet another spacer...stacking is bad. I'm thinking your 3.5 lift wasn't really a 3.5 lift at all.
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #36 of 71 Old 06-28-2013, 04:20 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Make sure your front sway bar is +/- 10 degrees from level on level ground. Check the sway bar bushings as well. They are cheap and easy to replace.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #37 of 71 Old 06-28-2013, 07:32 AM Thread Starter
hondakilla98
This lift is 6 years old. How fast do springs start to sag? I'll probably only have this for two or three years. So I'm looking for cheap solutions. So I can spend money on cool stuff like a winch. And it'll sit at about 3.9" after the spacers and winch. So I'll have some room for sag.
If I do go with 4.5 inch springs, what should I get? And are 4.5's alone going to be enough?
post #38 of 71 Old 06-28-2013, 05:14 PM Thread Starter
hondakilla98
I put the adapters, and Rubicon wheels/tires on today. I also took off the 5.9 lower valance, and the plastic trim on the front of the rear wheel well. It'll be fine to drive on the street, but it'll need some work before it's trail ready.
post #39 of 71 Old 06-28-2013, 05:24 PM
xcaliber81
I'd also double check the tire size, you said you are getting 255/55r17 tires? Those are a 28" tire, the 255/75r17 are a 32" tire
I read this multiple times am I missing something or did you just say a 28" and 32" tire the same?
xcaliber81 is offline
post #40 of 71 Old 06-28-2013, 09:28 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
My springs didn't sag like that with Arab front and kor rear bumper in over twelve years.
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #41 of 71 Old 06-28-2013, 10:08 PM Thread Starter
hondakilla98
I put 55 instead of 75. They are jk take offs. And measure out to 32".
post #42 of 71 Old 06-28-2013, 10:16 PM Thread Starter
hondakilla98
If I go with new springs would I just get 4.5" and it would settle about an inch with the bumper and winch? Or am I still going to need spacers? And put a .75" spacer in the back? Should I contact RE and ask them about replacing the springs?
Im also wondering if I need longer rear control arms. Ive only got 1/2"-3/4" between the front of my rear tire and the wheel well. Or maybe trim the bottom corner of the rear wheel well.
post #43 of 71 Old 06-29-2013, 03:33 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Check my pics. Get the 4.5 springs from RE or IRO. You may need longer control arms for the rear.
Contact Kolak from my SIG for prices.
Hunter
04 4.7 HO, limited
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
480.998.366
post #44 of 71 Old 06-29-2013, 09:18 AM
dnuccio
You dont want to center the rear tire in the wheel well. When the suspension flexes, the rear tire moves up and back. If you center it in the wheel well, it wont have as much room to move back and will rub when flexed
R.I.P. Ratmonkey
dnuccio is offline
post #45 of 71 Old 06-29-2013, 05:51 PM Thread Starter
hondakilla98
I flexed the rear of the jeep last night and the tire isn't getting much closer to the rear. It's still 1/2" from the front of the wheel well. And I had 2" at the back. I think it need to move back 1/2"-3/4". I bought spacers and the money I saved not putting springs in the front well go to adjustable lower control arms in the rear. If anyone has adjustable lower arms they want to sell, let me know. I also picked up an adjustable front track bar.
