rc control arm play - JeepForum.com
post #1 of 3 Old 08-24-2011, 05:01 PM Thread Starter
supniceyeah
rc control arm play
i'v been having a groaning/creaking coming from somewhere in my jeep, never really thought about it.
now theres a screeching when i hit bumps so i crawled under and start shaking things intill i found the problem. my rough country control upper rear control arms have play in the johnny joint end, side to side but also up and down. i'm going to go tighten them up, but if the up and down is an issue i don't want to tighten it and forget about it then have them fail on the highway or something. thoughts?
99 WJ,4.0, stock
93 ZJ,4.0, 5.5", 33x12.5 mts
96 ZJ,4.0, stock: deceased
87 YJ,4.2, stock: sold
supniceyeah is offline
post #2 of 3 Old 08-24-2011, 05:31 PM
speedbucket
you should be able to tighten them up or maybe your preload wasn't enough to begin with. im sure RC has rebuild kits available for cheap
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #3 of 3 Old 08-25-2011, 03:35 AM
mudruna
1994 ZJ
If you can't tighten them contact RC, they should warranty those for you. Had a similar issue with mine and they were great about sending me new ones for free.
94 ZJ Limited- 7" IRO premium, 4.56 gears on Elockers and Chromo's, 35" claws on beadlocks, Kevin's sliders
mudruna is offline
Tie Rod play? jamtoy ZJ Grand Cherokee Forum 4 10-28-2009 05:34 PM
Play in Adj. Control Arm, but not at the bushing. cherokeeja ZJ Grand Cherokee Forum 10 06-30-2009 03:07 PM
New control arms. now i have some play! ZJcrawler45 ZJ Grand Cherokee Forum 8 08-29-2007 04:56 PM
AC standard control UPGRADE to Climate control ? eschapiro ZJ Grand Cherokee Forum 1 01-24-2007 08:26 AM
swaping laredo climate control w/ Limited digital control atlien928 ZJ Grand Cherokee Forum 7 12-28-2003 03:51 AM
