The raw milk zj build - Page 4 - JeepForum.com
post #46 of 130 Old 02-21-2014, 10:03 PM Thread Starter
ian_red-zj
Originally Posted by PolkaPower View Post
Maybe the treads got messed up. Next time you are at the parts store grab a pack of them and try to put a new one in. Otherwise it's just a dirt collector hole.
I was able to get another grease zerk today and got it put in there. So how important is it to actually grease that joint up? Will it get messed up/wear out if I don't grease it or is it mostly for more suspension travel offroad?
ian_red-zj is offline
post #47 of 130 Old 02-24-2014, 06:29 PM
riot1987
grease it. it keeps em quiet and makes em last
Build thread^^
riot1987 is offline
post #48 of 130 Old 02-25-2014, 02:34 PM Thread Starter
ian_red-zj
Hey so I'm installing the u-joints into my new axle shafts and I don't know how to put in these full circle clips. I saw something on another site where the guy put them on before installing the u-joint into the yoke. Do I have to press it back out now or can I just stretch it over? All I got is regular and needle nose pliers, none of those special retaining clip ones.
post #49 of 130 Old 02-25-2014, 05:13 PM
Scopez
1994 ZJ
Called snap ring pliers, I advise getting a good pair as they come in handy. They make tons of different sized ones as well.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #50 of 130 Old 02-25-2014, 05:47 PM
riot1987
I 2nd this
Build thread^^
riot1987 is offline
post #51 of 130 Old 02-25-2014, 06:05 PM
Myusername1674
3rd it. You can get a cheap china pos for $5 at most places, it might be good enough for those snap rings. A good high quality pair is a good investment though
sent from, uh
95 FiveTwo ZJ, DD, Lifted, Locked on 35s,
(in progress)
Myusername1674 is offline
post #52 of 130 Old 02-26-2014, 06:37 PM Thread Starter
ian_red-zj
Ok long story, but I'm new to u-joints and such, and I destroyed one of the washers that holds the cap. What is this called and where can I find it? It's an Alloy USA x-joint; I'm not sure if it's a universal part, but I assumed it would be since it's just a washer. Advance Auto didn't have it though. I'd appreciate it if you guys could steer me in the right direction.
post #53 of 130 Old 02-27-2014, 03:10 PM Thread Starter
ian_red-zj
Nevermind about the washer. Alloy USA was kind enough to send me a replacement. I think it was called the thrust washer... Well at least I can replace the passenger side in the meantime which is the side that's broken. Lesson learned!
Edit: Alloy USA sent me a brand new u-joint shipped to my door free of charge! All I needed was the washer, but now I have a spare u-joint that would probably be capable of functioning if I needed it to. Some high quality customer service!
post #54 of 130 Old 03-04-2014, 08:04 PM Thread Starter
ian_red-zj
All right, I got the axles installed and threw in some new brake pads in the front and greased up the slide pins in the calipers. I had to press the caliper piston with a c-clamp in order to get the brakes back on, which I'm pretty sure is normal. I went for a little test drive and the abs light was on and braking power felt very weak. I pumped the brakes a few times but it was still the same. Any ideas? I try to post my questions here now rather than making a thread or struggling to find another thread that addresses the same issue.
post #55 of 130 Old 03-04-2014, 08:36 PM
riot1987
Kinda an obvious one but, when you clamped your caliper, did you overflow your reservoir and are you now low on fluid perhaps?
Build thread^^
riot1987 is offline
post #56 of 130 Old 03-05-2014, 01:28 AM
Myusername1674
Seams odd it'd feel week, maybe try bleeding the brakes just in case. I don't see how you could have damaged the caliper unless it was already getting bad
(in progress)
post #57 of 130 Old 03-05-2014, 06:23 PM Thread Starter
ian_red-zj
I think I'm good on fluid, I just topped it off recently. It felt better today, but as soon as I hit the brakes the abs light comes on. Is the abs light just the general code for anything wrong with the brake system?
post #58 of 130 Old 03-05-2014, 06:31 PM
Scopez
1994 ZJ
ABS light comes on due to an issues with ABS, you'll still have regular braking power.
Scopez is offline
post #59 of 130 Old 03-05-2014, 09:13 PM
WVZJ
Your new shafts probably don't have tone rings. Hence the ABS light
98 ZJ 5.2, LA n Locked, 242 sye, 35's
87 MJ, 4.0, 8.8, 33's, oba
07 Ram 2500 5.9 ctd
WVZJ is offline
post #60 of 130 Old 03-07-2014, 08:17 PM Thread Starter
ian_red-zj
You're absolutely right, that was the problem.
build lift mud tires , build thread , led light bar , lift and tire combination , winch bumper
