Rattle/scratchy noise - JeepForum.com
post #1 of 6 Old 02-03-2007, 02:14 PM Thread Starter
CWMac
From my engine bay front left ( RHD so not saying driver side :P ) when idle or driving i hear a scratchy rattle noise. Sounds like something spinning , so im assuming its the turbo but should it make a noise like it does?
Thanks.
CWMac is offline
post #2 of 6 Old 02-03-2007, 05:07 PM
matt.x
matt.x's Avatar
you've got a turbo?
Red Jeep Club Member #237
matt.x is offline
post #3 of 6 Old 02-03-2007, 06:52 PM Thread Starter
CWMac
Ok if you drive and build the revs to around 2k and floor it, what gives the kick then? keeping yer foot on floor ,once you hit 70 you get a second kick and the same noise.
OK so im taking it by the smart arse answer above theres no turbo but what makes the spinning scratchy sound in the engine bay? it sounds like a turbo venting every so often so i assumed it was one.
And i dont mean the kick from teh actually flooring ie kickdown/overdrive what ever you guys call it over there. The engine even changes pitch.
CWMac is offline
post #4 of 6 Old 02-03-2007, 07:26 PM
cmonson
anything that spins could make the "turbo" sound...haha
I would check the alternator, steering pump, ac compressor, idler pulley, fan clutch.
cmonson is offline
post #5 of 6 Old 02-03-2007, 09:21 PM Thread Starter
CWMac
Most of them are at the front all will be cycling at same speed as sepr belt.
Obviously you red knecks are lost here as you all seems to be with anything i ask. if it was which bb to go for or which "tire" to use its fine.
Forget it .
CWMac is offline
post #6 of 6 Old 02-04-2007, 07:41 AM
greasefingers
greasefingers's Avatar
1994 ZJ
We can help you until you learn to write a proper sentence.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
4.7 rattle noise when accelerating Blackdout00wj ZJ Grand Cherokee Forum 6 02-05-2010 01:15 PM
Bad WJ Drivetrain noise/rattle superdave35 ZJ Grand Cherokee Forum 0 12-20-2009 11:03 PM
Noise and rattle from under the car will_b ZJ Grand Cherokee Forum 4 03-29-2007 06:33 AM
Rattle noise yiyo ZJ Grand Cherokee Forum 5 12-25-2006 11:48 PM
rattle noise nashmd454 ZJ Grand Cherokee Forum 2 04-08-2004 10:25 PM
