Random clunking noise - JeepForum.com
post #1 of 18 Old 01-24-2012, 05:00 PM Thread Starter
BenHoleton
I have a 95 ZJ with a random clunking noise, always at low speeds, and when i either brake or accelerate from a complete stop. Doesn't happen all the time. Any thoughts? It sounds like (though not 100% sure) it's coming from directly below my feet while driving
BenHoleton is offline
post #2 of 18 Old 01-24-2012, 05:24 PM
SAR-Swimmer
Drive shaft U-joints, maybe?
SAR-Swimmer is offline
post #3 of 18 Old 01-24-2012, 05:57 PM
GaryE30
Engine Mounts?
Control Arms?
Swaybar Endlink?
Just check these things for any play. That's where I would start
GaryE30 is offline
post #4 of 18 Old 01-24-2012, 08:41 PM Thread Starter
BenHoleton
I've replaced sway bar liks and control arm bushins within the last 6 months. Will look at engine mounts. The driveshaft u joints are new as well
post #5 of 18 Old 01-24-2012, 11:17 PM
Mickey_D
I get it too. Mine is due to a failed sway bar end link. I know you say you replaced them, but I'd check them again. Also check the sway bar bushings. I also get a good clunk if I really get on it from a dead stop. Yes, I already have the replacement driver's side engine mount sitting on my floor boards. Just waiting on a day where I won't get a snow drift down the back of my neck while changing it.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #6 of 18 Old 01-24-2012, 11:36 PM
zjluke
had the same thing if you have a Limited Slip rear end it could need a fluid change. i did one and it went away might also want to check front axles if its full time awd buy jacking the front end up leaving it in park and if it spins and makes nosie thats your problem
zjluke is offline
post #7 of 18 Old 01-25-2012, 02:26 AM
KoreaZJ
1994 ZJ
Loose t-case chain?
KoreaZJ is offline
post #8 of 18 Old 01-25-2012, 08:16 AM Thread Starter
BenHoleton
Luke, just had the fluid in both differentials changed. I'll check the rest of the stuff.
post #9 of 18 Old 09-03-2013, 11:45 PM
ZJNewbi3
ever find your solution? I'm having the same problem and looking to fix it before winter hits.
Just trying to keep her goin'!!
ZJNewbi3 is offline
post #10 of 18 Old 09-04-2013, 05:34 AM
shillson
I had the same problem in my 98 ZJ. Turns out the front stabilizer links were BOTH broken. Replaced them and the bolts and all is well.
shillson is offline
post #11 of 18 Old 09-04-2013, 07:28 AM
Scopez
1994 ZJ
Just replaced mine because of this...I'd suggest getting Moogs.
Btw: this thread is a 1.5yrs old.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #12 of 18 Old 09-04-2013, 08:30 AM
ZJNewbi3
wait did u replace the bushing or the link? the links sond expensive and from your advice on my last thread, im already down $70 for a starter
ZJNewbi3 is offline
post #13 of 18 Old 09-04-2013, 08:41 AM
Scopez
1994 ZJ
I replaced the link. Haha, it was $44 each link. You can get some for about $26, that's just the store brand. Moogs have greasable fittings on them.
Scopez is offline
post #14 of 18 Old 09-04-2013, 09:50 AM Thread Starter
BenHoleton
It ended up being the adjustable track arm not being fully tight. It seemed tight on the ground. Put it on jack stands and it moved. Torqued it. All was fine
post #15 of 18 Old 09-04-2013, 09:52 AM Thread Starter
BenHoleton
Oh, and when I replaced end links, get the moog part number and then buy on amazon for half price
Very odd & random rear clicking/clunking noise. Need major help with this one!! JOSHMAN00 WK Grand Cherokee & XK Commander Forum 15 01-15-2015 04:18 PM
Clunking noise jager00 WK Grand Cherokee & XK Commander Forum 3 03-11-2011 12:00 AM
Clunking Noise 96CherokeeJeep ZJ Grand Cherokee Forum 0 05-26-2010 09:08 PM
Clunking Noise..... HELP!! ScubaJeep2003 ZJ Grand Cherokee Forum 3 04-03-2007 11:39 AM
Clunking noise? svmetalman09 ZJ Grand Cherokee Forum 1 03-07-2007 08:14 PM
