Random Caliper Grab.. Help! - JeepForum.com
post #1 of 7 Old 04-01-2014, 08:25 PM Thread Starter
zack987
Okay, So i've been getting really frustrated with this whole thing. I have a 1994 Jeep Grand Cherokee Limited with the 5.2L V8 and it drives fine up until say 10 or 20 miles you've driven. Once you've done that, there begins to be a random grab coming fron the front right. I've replaced almost everything over there, and i'm completely stumped now as to whats causing it. Brand new caliper, rotor, and rubber brake hose that goes to the caliper. Still does it. And thoughts or suggestions on the issue would be greatly appreciated! Thanks!
zack987 is offline
post #2 of 7 Old 04-02-2014, 04:47 AM
AVR2
Obvious question, but have you tried disabling the ABS just to see if that's the issue?
AVR2 is online now
post #3 of 7 Old 04-02-2014, 05:31 AM
jeepjeepster
Maybe check this?? Mine was doing the same thing. After driving awhile i would start to get a thumping sound from the right front brake. If i applied the brakes it would stop, then soon return.
http://www.jeepforum.com/forum/f13/n...-pads-2207057/
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #4 of 7 Old 04-02-2014, 07:06 AM Thread Starter
zack987
The ABS does not work on the car, the parts all fell off long ago
zack987 is offline
post #5 of 7 Old 04-03-2014, 08:46 PM Thread Starter
zack987
Jeepjeepster, i tried that today, that did not work, does anyone have any other ideas as to why this is happening?
zack987 is offline
post #6 of 7 Old 04-03-2014, 09:12 PM
JS97ZJ
A rotor can be destroyed in a short period of time if the lugs aren't torqued down evenly. The heat build up will warp the rotor when they aren't tightened evenly.
JS97ZJ is offline
post #7 of 7 Old 04-03-2014, 09:53 PM Thread Starter
zack987
All lugs are tightened down evenly and correctly, checked that al today.
zack987 is offline
