Ran a smaller spare for too far... - JeepForum.com
post #1 of 13 Old 07-17-2017, 07:57 AM Thread Starter
congerz83
I put a smaller spare on my 5.9 to try to get home after a blowout...
I knew I was playing with fire... And after about 20 miles KA-BOOM...
My question is... Did I damage the transfer case? Or the front diff? I have a 242 sitting in my old 4.0 that I could put in, but I'm not really interested in putting a front diff in this thing.
congerz83 is offline
post #2 of 13 Old 07-17-2017, 08:11 AM
mosey2001
You will of course have to pop them open. I have seen this affect the diff. However the only time I was actually there to see. The entire case of the diff literally cracked in half. My experience was with a full size trucks however so maybe that was different all together.
I'd pull diff covers first.
Sent from my SM-G900V using Tapatalk
mosey2001 is offline
post #3 of 13 Old 07-17-2017, 12:05 PM
kg6mov
Hears the voices
kg6mov's Avatar
You probably blew the chain on the t-case, or you shredded the VC.
Should have pulled the front driveshaft . . .
Pull the diff cover to find out, then pull the front shaft and see if the front output on the t-case spins free.
kg6mov is offline
post #4 of 13 Old 07-17-2017, 12:31 PM
snkenai
I bought mine with the front diff destroyed from same tire issue. It ruins the viscus coupling and throws too much pressure on the front diff. I pulled the front drive shaft and front axle cv joints. reinstalled the stub axles to hold the hub bearings. Now it's drive-able as 2wd, temporary for occasional short errands. Not maybe recommended, but doable.
Steve
snkenai is offline
post #5 of 13 Old 07-17-2017, 12:50 PM
jeepjeepster
So whats the symptoms? What size was the spare tire?
My 94 came with a donut spare tire.. Never used it and probably never would for obvious reasons.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline
post #6 of 13 Old 07-17-2017, 03:22 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Whoever came up with donut temporary spares should have their balls in a vise.
HighLonesome is offline
post #7 of 13 Old 07-17-2017, 03:47 PM
kg6mov
Hears the voices
kg6mov's Avatar
Jeep actually did a recall for donuts on 249 equipped ZJ's because of this issue.
kg6mov is offline
post #8 of 13 Old 07-18-2017, 05:54 AM
jeepjeepster
For whatever reason it was only on certain years... And are you sure it was a recall and not a TSB? Im not sure honestly. My 94 does not have a recall listed for the spare tire.
I remember someone posting that the donut spare works on the 93-95 ZJ's b/c the VC allows for more slip... No idea if that is true but Im not risking it. Ill just get it towed if I have a flat I suppose...
2004 KJ w/90,300 mi
post #9 of 13 Old 07-18-2017, 10:18 AM
Timo_90xj
Timo_90xj's Avatar
No matter if you have a '93-'95 or a '96-'98, a donut spare will destroy the VC very quickly.
IIRC the donut spare tire thing was a TSB, but they were replaced by the dealership to a full size one. Later ZJs that had a 249 came with a full size spare from the factory.
***Under construction***
Timo_90xj is offline
post #10 of 13 Old 07-18-2017, 11:01 AM
jeepjeepster
I was thinking it was a TSB but wasnt sure.. From what I understand that only applied during the warranty period.. Think my warranty has ran out
2004 KJ w/90,300 mi
post #11 of 13 Old 07-18-2017, 11:15 AM
Mopar4U
Why does a smaller tire destroy the transfer case?
Mopar4U is online now
post #12 of 13 Old 07-18-2017, 11:25 AM
BorderWalker
It's due to the sensitivity of the Viscous Coupler. it wears out due to heat and uneven tires [of which a donut is obv not the same as other 3] causes more heat and use.
._________.ooooo.
/ŻŻŻ|ŻŻ|ŻŻ\ŻŻŻŻŻ\,____
L/ŻŻ\\__|__|"/ŻŻŻ\=llllll=\
_(Ż))===)).....(Ż))===))Ż
BorderWalker is offline
post #13 of 13 Old 07-18-2017, 01:00 PM
kg6mov
Hears the voices
kg6mov's Avatar
A smaller tire spins at a different speed, so the VC sees a speed differential and locks up. Normally that's a good thing because a speed differential means that a wheel or wheels are slipping and locking up the VC sends power out evenly so the wheels with traction can bite, eliminating the speed differential. Of course the smaller spare will never "bite" and the VC will cook.
kg6mov is offline
