Rain water on ZJ driver's floorboard - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Rain water on ZJ driver's floorboard
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-16-2010, 10:03 AM   #1
TX98ZJ
After about 2 inches of rain yesterday, my drivers floorboard is soaked. I have seen several posts about the condensate leak, but that is not the problem. Does anyone know if there is a common cause or do I need to get a buddy with a water hose and start searching?
TX98ZJ is offline   Reply With Quote Quick reply to this message
Unread 01-16-2010, 10:09 AM   #2
newfieZJ
Door seal maybe ? Look at the forward side by the hinges .
newfieZJ is offline   Reply With Quote Quick reply to this message
Unread 01-16-2010, 11:34 AM   #3
lar4305
I had the same thing, It was coming in from the drivers side hinges. Pull off the kick panel, and you will maybe see the water stains leaking from the spot were it bolts on to the body. There is also a clear plastic vapor seal that covers the access to the hinges. Pull back the rug there to. Look for the trail. Good luck.
1997 zj, 242 selec trac, 4.0l. son has a 96 grand cherokee 4.0l 242.Wife has a ford mini van.
lar4305 is offline   Reply With Quote Quick reply to this message
Unread 01-16-2010, 11:53 AM   #4
ZJJay
ZJJay's Avatar
I've heard that sometimes the roof rack rails can leak. However, I'd expect the headliner would get wet. Luckily my roof rack is water tight.
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline   Reply With Quote Quick reply to this message
Unread 01-16-2010, 12:29 PM   #5
TX98ZJ
Door seal is ok. I also checked the drains on the sunroof, they are open. I will pull that kick panel and look at the hinges. I looked at the firewall and there are no signs of water, also the carpet is wet only on the floorboard, not up higher near the fire wall. Maybe points to the hinges.
I haven't had any water on the headliner, so I agree it probably isn't the roof rack, but you never know. I will do a quick check there too.
It happened once before about a year ago and had not happened since. I hate intermittent problems.
Thanks for the ideas.
Unread 01-18-2010, 03:00 PM   #6
RobinsonFam1
crawl underneath and see if there are any holes or plugs not sealed too. that was 1 of my leaks but have since popped another one....ugh..
RobinsonFam1 is offline   Reply With Quote Quick reply to this message
