Rain water on ZJ driver's floorboard - JeepForum.com
post #1 of 6 Old 01-16-2010, 09:03 AM Thread Starter
TX98ZJ
After about 2 inches of rain yesterday, my drivers floorboard is soaked. I have seen several posts about the condensate leak, but that is not the problem. Does anyone know if there is a common cause or do I need to get a buddy with a water hose and start searching?
TX98ZJ is offline
post #2 of 6 Old 01-16-2010, 09:09 AM
newfieZJ
Door seal maybe ? Look at the forward side by the hinges .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #3 of 6 Old 01-16-2010, 10:34 AM
lar4305
I had the same thing, It was coming in from the drivers side hinges. Pull off the kick panel, and you will maybe see the water stains leaking from the spot were it bolts on to the body. There is also a clear plastic vapor seal that covers the access to the hinges. Pull back the rug there to. Look for the trail. Good luck.
1997 zj, 242 selec trac, 4.0l. son has a 96 grand cherokee 4.0l 242.Wife has a ford mini van.
lar4305 is offline
post #4 of 6 Old 01-16-2010, 10:53 AM
ZJJay
ZJJay's Avatar
I've heard that sometimes the roof rack rails can leak. However, I'd expect the headliner would get wet. Luckily my roof rack is water tight.
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline
post #5 of 6 Old 01-16-2010, 11:29 AM Thread Starter
TX98ZJ
Door seal is ok. I also checked the drains on the sunroof, they are open. I will pull that kick panel and look at the hinges. I looked at the firewall and there are no signs of water, also the carpet is wet only on the floorboard, not up higher near the fire wall. Maybe points to the hinges.
I haven't had any water on the headliner, so I agree it probably isn't the roof rack, but you never know. I will do a quick check there too.
It happened once before about a year ago and had not happened since. I hate intermittent problems.
Thanks for the ideas.
TX98ZJ is offline
post #6 of 6 Old 01-18-2010, 02:00 PM
RobinsonFam1
crawl underneath and see if there are any holes or plugs not sealed too. that was 1 of my leaks but have since popped another one....ugh..
RobinsonFam1 is offline
water in floorboard of 05 Grand orangez WK Grand Cherokee & XK Commander Forum 6 01-24-2010 01:24 PM
Mystery wires in driver's side floorboard?!? (pics) jeremiahgreer ZJ Grand Cherokee Forum 10 01-21-2010 07:47 AM
Water in passenger FLoorboard nccherokee ZJ Grand Cherokee Forum 2 09-06-2006 07:34 PM
96 Laredo - Water in driver's floorboard? timewalker ZJ Grand Cherokee Forum 2 02-02-2006 03:34 PM
Water in back floorboard Brent33 ZJ Grand Cherokee Forum 7 08-19-2005 03:57 PM
