radios that fit 96 grnd cher laredo - JeepForum.com
post #1 of 8 Old 09-07-2005, 10:39 AM Thread Starter
wilfsdad
my factory radio is shot, all the buttons are dead on the front panel, and the cd player skips a lot. i was looking at buying a replacement 2nd hand from ebay. my model is p04858517, but i noticed there are a whole host of other part numbers for radios that look identical to mine (po4704383ah, p04704382ab, etc) are these all the same radio but have different part numbers because they were in a plymouth or a dodge rather than a jeep??? i'm confused and don't want to get the wrong one.
wilfsdad is offline
post #2 of 8 Old 09-07-2005, 10:48 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Not sure how much the radio's you are looking at but you'll get better sound and it'll most likely be cheaper to buy an aftermarket deck. Check out www.crutchfield.com and fill in the info on what Jeep you have and it'll display all the deck's that'll fit your Jeep, give you a fill in plate to make it fit properly, and a wiring harness to make the hookup easy.
-Ryan
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 8 Old 09-07-2005, 10:49 AM
Decipticon
You should look at an aftermarket model. They are MUCH better than stock, and still fairly reasonably priced (around $100 for a decent model). Unless you really want to keep everything in your Jeep stock, i would really recommend upgrading. Crutchfield and Ebay would be the places to look.
Jesus is coming. Look busy.
Decipticon is offline
post #4 of 8 Old 09-07-2005, 11:11 AM Thread Starter
wilfsdad
stock v aftermarket
i've bought from crutchfield many times. the problem is that nowadays it is getting very difficult to buy a cd/cassette/radio combo (i still love cassettes). so i'd prefer to keep it stock. i havethe infinity gold soundsystem and sounds pretty good to me.
wilfsdad is offline
post #5 of 8 Old 09-07-2005, 11:16 AM
ArloGuthroJeep
Mr. Hyde!
$269.99 for cd/cassette deck: http://www.crutchfield.com/S-0nmaI7K...0&I=140FXCD550
post #6 of 8 Old 09-07-2005, 08:20 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I have the sony exploid. Really like it. I bought the cover for it and the wiring harness at an audio store. Very cheap and works like a champ.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #7 of 8 Old 09-07-2005, 11:31 PM
PumaZJ
Cassette? whats that?
musta been before my time.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #8 of 8 Old 09-08-2005, 07:43 AM
Meerkat
Normally, the different part numbers indicate different units.
There are units that have AM/FM only, AM'FM/cassette, AM/FM/Cassette/CD, AM/FM/cassette/remote CD. The Infinity Gold AM/FM/cassette/CD you have has a three band equalizer, while the one with remote CD has a 5 band equalizer.
Pretty much all these units will fit in your Jeep (as long as they are for the ZJ and not the WJ), however, a key issue is the steering wheel control connector. The base units do not have a connector for that function.
Reputable sellers will specifically point out whether or not a radio has that function. If it isn't mentioned, assume it doesn't exist.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
96 Grnd Cherokee won't start liampshanahan ZJ Grand Cherokee Forum 1 11-15-2008 10:07 PM
99 Grnd Cherokee A/C not cold Daddy Dumpsalot ZJ Grand Cherokee Forum 15 06-08-2007 10:42 PM
Fuel filter for Jeep Grnd Cherokee Overland dennislay ZJ Grand Cherokee Forum 3 09-27-2005 02:05 PM
99 Grnd Cherokee won't start?!? 99Laredo WJ Grand Cherokee Forum 5 04-13-2004 01:22 PM
97 Grand Cher Laredo bluYJ ZJ Grand Cherokee Forum 1 06-05-2003 12:06 AM
