Radio replacement with infinity gold amplifier - Page 2 - JeepForum.com
post #16 of 26 Old 12-21-2011, 02:49 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
You likely have never taken the head unit apart. I used to repair this stuff for a living. If you want to call low pay and no benefits a living. The head unit is built like a brick ****house. The heat sinks in the power amp section are at least twice the size of aftermarket stuff. These units last over a decade.
HighLonesome is online now
post #17 of 26 Old 12-21-2011, 03:08 PM
somebody5788
1994 ZJ
I hope you see the irony in your post. I mean your saying they last forever but you used to repair them
2006 Honda 919 - Summer Daily
1994 Jeep ZJ - RC Long Arms | RE 4.5" springs | Bilstein 5100's | RE SS brake lines | Falken 31x10.5-15 tires | Flatland 4x4 bumpers | Summit Soft 8's 15x8 3.75 BS wheels
somebody5788 is offline
post #18 of 26 Old 12-21-2011, 03:14 PM
HighLonesome
I quit doing that line of work long before Jeep and Infinity. But I've seen enough aftermarket junk to know WTF.
post #19 of 26 Old 12-21-2011, 03:17 PM
somebody5788
1994 ZJ
Well in my other ZJ the unit used to overheat and start cutting out if I had the heater on.
post #20 of 26 Old 12-21-2011, 03:33 PM
HighLonesome
How old was it?
post #21 of 26 Old 12-24-2011, 07:09 AM
congerz83
I'm having a huge problem with my sisters 5.9... I installed this head http://www.crutchfield.com/p_158GT56...FFBrand%7cSony, bought it from crutchfield, plugged in the two harness' that came with the kit wired everything up, but all I get out of the two (door and tweeter) speakers on the driver-side front is white noise. Not remembering if the front driver-side speakers ever worked at all, I plugged in the stock radio to find the same problem. Reading this thread has shed a little light on what questions to ask to get this much needed help.
1) What could be causing this problem? Could both tweeter and door speaker blow out at once? Or is there a bad connection between the radio and the speaker that renders both speakers useless.
2) Do I/can I bypass the original amplifier? If so, how hard is this to do?
3) Does the radio in the link have a suitable "pre-amp"? If I bypass/remove the stock amp, will I lose volume?
I've checked everything aside from ripping the door panel off. After crashing her 5.9 last week and getting it repaired, the stereo is a christmas present to her and I'd love to be able to give it to her tonight. Any help is greatly appreciated.
congerz83 is offline
post #22 of 26 Old 12-24-2011, 09:02 AM
PolkaPower
If the radio has a pre amp then it would sound better to use that. White noise is usually a bad ground or wires interfering with one another. Those tweeters are so tinny I took them out and I like that better. I am just rolling with 4 jbls in my doors without the sound bar and it sounds better than with all of the infinity speakers working. Good luck.
PolkaPower is offline
post #23 of 26 Old 12-18-2013, 10:40 PM
rockride
Anyone know what level the Infinity gold amp needs?
I am wondering if the infinity gold amp takes line level inputs from the head unit, or does it take an amplified signal?
rockride is offline
post #24 of 26 Old 07-07-2014, 02:22 AM
drd26
2 ohms speaker??
Can i put a 4ohm speakers beucause the originals one burned away
drd26 is offline
post #25 of 26 Old 07-07-2014, 02:40 AM
kg6mov
Hears the voices
kg6mov's Avatar
Yes.
kg6mov is offline
post #26 of 26 Old 07-08-2014, 08:48 AM
rockride
You can use 4ohm speaker, it will just require more power(2x) to attain the same volume as with 2ohm.
Sent from AutoGuide.com Free App
rockride is offline
infinity , radio , replace
1998 GC with Infinity Gold System, Radio Help Zalexander ZJ Grand Cherokee Forum 8 12-26-2011 02:58 PM
Good replacement for Infinity gold speakers on ZJ? steve718 ZJ Grand Cherokee Forum 15 07-05-2008 05:58 AM
infinity gold amplifier problems joeyschribar ZJ Grand Cherokee Forum 7 04-30-2006 12:17 AM
’98 GC Lim. –Infinity Gold speaker’s needs replacement - suggestions? WebMaster9000 ZJ Grand Cherokee Forum 22 04-04-2006 09:52 PM
Infinity Radio is shot - need replacement cfkingfish ZJ Grand Cherokee Forum 2 04-30-2004 10:02 PM
