Radio power problem - JeepForum.com
post #1 of 6 Old 05-15-2012, 09:31 AM Thread Starter
Camswe
Radio power problem
Hey, so i fixed most of the electrical issues i was having by cleaning my grounds but still one persists; when i push the power to my radio it turns on and displays the time for 6 seconds and then goes blank i can do this multiple times and it always does the same thing never hear any sounds and wont play any CD's. I was told maybe i should pop the head unit out and check the wires and grounds in the back? any suggestions?
Camswe is offline
post #2 of 6 Old 05-15-2012, 10:16 AM
edpmedic
I am not really into radios but I would think you should do that if anything on the outside don't work. Maybe your having trouble with the power on/off switch being bad? I'm just guessing my radio works but I have no way to know what stations I am tuned to, plus my antenna when I turn it on or off makes noise to pull it up or down but it stays up. Also if I don't have a tape on the player the radio will not come on. If I pull the tape out the radio doesn't work....Other then that it sounds fine.
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline
post #3 of 6 Old 05-15-2012, 10:22 AM
gearheadnick
That would be a good place to start. If you think the ground is an issue, make your own ground lead.
There's also the possibility that your head unit is dying or dead. The easiest way to eliminate that possibility is to pull the radio out of the dash, take it over to your battery, and directly hook up power and ground to the battery. Make sure you hook up both power wires to positive, one is a constant power, the other is the keyed on power. If it still acts the same, your wiring isn't the problem.
My cylinder head overhaul:
My transmission overhaul: http://www.jeepforum.com/forum/f13/how-change-transmission-electronics-1560948/
gearheadnick is offline
post #4 of 6 Old 05-15-2012, 12:09 PM Thread Starter
Camswe
OK i will do this shortly too test and ill see if i see any bad connections or any loose wires.
Camswe is offline
post #5 of 6 Old 05-15-2012, 12:58 PM
ShytWeAllDo
Had exact same issue.. gave up, went to betbuy. The guy said that he had to run a new power wire.
ShytWeAllDo is offline
post #6 of 6 Old 05-15-2012, 05:58 PM
gearheadnick
That's exactly why I don't reuse the factory wiring. It doesn't take long to put in, and I know that the new wiring won't be an issue.
audio , electrical
radio has no power zxknight76 ZJ Grand Cherokee Forum 1 04-11-2010 11:55 PM
no power on radio ? NeverL8 ZJ Grand Cherokee Forum 10 03-26-2010 08:21 AM
Power to the radio, without the key? Windowsrookie ZJ Grand Cherokee Forum 18 10-18-2008 07:49 AM
No power to radio, A/C, Computer, power locks drumtex ZJ Grand Cherokee Forum 2 05-12-2008 12:37 AM
Dead radio, interior lights, power mirrors and power locks. Lisa ZJ Grand Cherokee Forum 5 09-04-2005 10:34 PM
