radio expert needed - JeepForum.com
post #1 of 13 Old 08-08-2013, 06:31 PM Thread Starter
da8
radio expert needed
I bought a 98 zj limited. Only the front right door speaker worked. I thought it might be the radio so I changed that out. it wasn't. I thought it might be the speakers so I took the rear door speaker out and put a new one in. Nothing, no sound. Anyone know why this would be happening. Only sound in the right front door speaker. The tweeters in the dash do not work either.
Thanks
da8 is offline
post #2 of 13 Old 08-08-2013, 06:49 PM
JeepNicholson
It's a long shot, but make sure the pins in the radio harness plugs aren't pulling out
JeepNicholson is offline
post #3 of 13 Old 08-08-2013, 06:57 PM
jtackerman28
It's bad wires.
3.5 re lift, double sheer front tb, 31" wrangler duratecs
jtackerman28 is offline
post #4 of 13 Old 08-08-2013, 06:57 PM
jtackerman28
You'll have to run all new wires.
post #5 of 13 Old 08-08-2013, 07:16 PM
BlastMasta
Does it have a factory amp?
BlastMasta is offline
post #6 of 13 Old 08-08-2013, 07:44 PM Thread Starter
da8
not sure, how do i tell?
da8 is offline
post #7 of 13 Old 08-08-2013, 07:53 PM
JeepNicholson
It'll be under the back seat and looks like this
http://cdn.stripersonline.com/1/13/1...tach437125.jpg
ZJ FSM
https://drive.google.com/folderview?...Fk&usp=sharing
post #8 of 13 Old 08-08-2013, 08:00 PM Thread Starter
da8
yes, it has it. what now?
da8 is offline
post #9 of 13 Old 08-08-2013, 09:17 PM
jabba974
Good possibility its the amp...try replacing it or eliminating it from the system..
jabba974 is offline
post #10 of 13 Old 08-08-2013, 10:10 PM
wickedkingszj
Did you try to replace the factory head unit with an aftermarket or do you plan on doing so?
wickedkingszj is offline
post #11 of 13 Old 08-08-2013, 11:31 PM
Candymancan
It could be the amplifier.. You can get them from a Junkyard limited (or Laredo if it had it) for like $10.. I found the original amp in a 5.9 for my 5.9 which previous owner took out.. its 180watts.. I think yours is something like 90 or whatever got mine for 10$
However it could be bad wiring... My 98 Laredo has no amp, just the head unit and the front speakers don't work very good anymore like no sound coming from them... It just be bad speakers I know is bad so I unplugged it
Candymancan is offline
post #12 of 13 Old 08-10-2013, 09:21 PM Thread Starter
da8
Thanks Everyone, it was the amp. Works fine now
da8 is offline
post #13 of 13 Old 10-15-2013, 07:08 PM
Rosslato
1994 ZJ
I'm having a similar problem, did you replace the amp or find the problem?
Rosslato is offline
