-   -   radio expert needed (http://www.jeepforum.com/forum/f13/radio-expert-needed-1559719/)
da8 08-08-2013 06:31 PM
radio expert needed
I bought a 98 zj limited. Only the front right door speaker worked. I thought it might be the radio so I changed that out. it wasn't. I thought it might be the speakers so I took the rear door speaker out and put a new one in. Nothing, no sound. Anyone know why this would be happening. Only sound in the right front door speaker. The tweeters in the dash do not work either.
Thanks
JeepNicholson 08-08-2013 06:49 PM
It's a long shot, but make sure the pins in the radio harness plugs aren't pulling out
jtackerman28 08-08-2013 06:57 PM
It's bad wires.
You'll have to run all new wires.
BlastMasta 08-08-2013 07:16 PM
Does it have a factory amp?
da8 08-08-2013 07:44 PM
not sure, how do i tell?
JeepNicholson 08-08-2013 07:53 PM
It'll be under the back seat and looks like this
http://cdn.stripersonline.com/1/13/1...tach437125.jpg
ZJ FSM
https://drive.google.com/folderview?...Fk&usp=sharing
da8 08-08-2013 08:00 PM
yes, it has it. what now?
jabba974 08-08-2013 09:17 PM
Good possibility its the amp...try replacing it or eliminating it from the system..
wickedkingszj 08-08-2013 10:10 PM
Did you try to replace the factory head unit with an aftermarket or do you plan on doing so?
Candymancan 08-08-2013 11:31 PM
193 Attachment(s)
It could be the amplifier.. You can get them from a Junkyard limited (or Laredo if it had it) for like $10.. I found the original amp in a 5.9 for my 5.9 which previous owner took out.. its 180watts.. I think yours is something like 90 or whatever got mine for 10$
However it could be bad wiring... My 98 Laredo has no amp, just the head unit and the front speakers don't work very good anymore like no sound coming from them... It just be bad speakers I know is bad so I unplugged it
da8 08-10-2013 09:21 PM
Thanks Everyone, it was the amp. Works fine now :)
Rosslato 10-15-2013 07:08 PM
I'm having a similar problem, did you replace the amp or find the problem?
The time now is 05:50 AM.
