-   -   Radio Died today (and pwr ant. went down) (http://www.jeepforum.com/forum/f13/radio-died-today-pwr-ant-went-down-296838/)
cmckeon 07-25-2006 12:37 PM
i was driving along like any other person listening to my cd player and ..... no more music i think i blew a fuse to the power antenna and amp but have no clue where it is i have checked the fuse on the back of the stereo and the fuse panel and under the hood as well, were is that fuse hiding anyone know???
HighLonesome 07-25-2006 01:27 PM
If the power antenna went down, then it's not that fuse. Likely the radio died and that signalled the antenna to lower, maybe due to a fuse. Not sure what fuse it is.
cmckeon 07-25-2006 01:38 PM
the radio still works fine i tried it in another car, it's almost like i fried a wire or something
GreenDean 07-25-2006 04:35 PM
there are two poawr wires going to the radio.
One power the unit when you turn the ignition on.
The other supplies power 24/7 to keep your settings and clock correct.
Here's the wire guide for the radio.
The "+12 volt ignition wire" is the one you want to look for.
Make sure the pin in the plug is good.
if everything behind the radio looks good.
its probably a fuse.
Did you check the fuses yet?
The radio is fuse #10. It's a red 10 amp fuse.
http://i45.photobucket.com/albums/f9...ald/wiring.jpg
cmckeon 07-25-2006 11:39 PM
i have checked the fuses and the amp under the back seat i wouldn't have posted if i was a fool with no idea that is a waste of time, my prob is a fuse for sure but i don't know the location of it, the radio works just no power ant which turns on the amp and allows music to come out
greasefingers 07-25-2006 11:45 PM
There is nothing better than an OEM stereo failing. It justifies hunting down a new HU … and speakers … and amp and anything else that tickles your fancy. It is like opening Pandora’s Box
HighLonesome 07-26-2006 11:04 AM
Maybe you should buck up for an FSM and not have to depend on others for fuse location then.
cmckeon 07-26-2006 12:24 PM
i have a fsm and it's not in there thats the reason i came to jeep forum
The time now is 12:54 PM.
