Radiator not draining - JeepForum.com
post #1 of 5 Old 06-01-2003, 09:23 PM Thread Starter
BajaZJ
Today I tried to flush my radiator and change the fluid on my '94 ZJ 5.2L V8. I could only turn the petcock a 1/4 turn counter clockwise using a pair of pliers and did not want to force it any further. Nothing came out of the spout. Am I doing something wrong or could I have a bigger problem with my radiator?
Thanks,
Mike
BajaZJ is offline
post #2 of 5 Old 06-02-2003, 01:42 AM
Zaphod
SACPOWERTV.com
Zaphod's Avatar
1981 J-Series Truck
I just changed my radiator hoses and thermostat a month ago. same year and model as yours. the plug on the bottom of the radiator is a small white plug. unscrew it, and pull it away from the radiator. it will not come out all the way, but fluid will drain out. it is rather difficult to direct the flow, so be on ground you do not mind getting soaked in coolant fluid.
if nothing still comes out, you were running on an empty radiator, which is not physically possible. so something be wrong. best of luck. hope this helps.
Ryan
81 J20 8400#
"The existence of flamethrowers is proof that someone,
somewhere, said to himself, "I want to set those people
over there on fire, but I don't feel like walking over there to do it."
Zaphod is offline
post #3 of 5 Old 06-02-2003, 05:24 AM Thread Starter
BajaZJ
Sonar
Was your plug difficult to turn? I don't want to break a 9 year old piece of plastic, so I didn't force it. Mine is black (it may have been white as some point) with a tab where I was able to get a pair of pliers on it. It also has a spout beneath it where you can attach a hose to direct the flow. Is this like your setup? I was assuming that it is just a ball valve of some type and that's why it wouldn't go beyond a 1/4 turn. When I opened the radiator cap, the radiator was full and there is the proper amount of fluid in the overflow tank.
Mike
BajaZJ is offline
post #4 of 5 Old 06-02-2003, 10:33 AM
Zaphod
SACPOWERTV.com
Zaphod's Avatar
1981 J-Series Truck
Hmm, one of us must have a non-stock radiator. Your setup sounds easier (and cleaner) to use. Can't give you any advice on what I know nothing about. Best of luck.
Ryan
81 J20 8400#
Zaphod is offline
post #5 of 5 Old 06-03-2003, 01:40 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I just got a bucket and cut a hole in the bottom hose for it to drain out.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
97 battery draining? Deadhorse ZJ Grand Cherokee Forum 1 03-31-2009 11:08 AM
New PCM but still draining battery Nemo04660 ZJ Grand Cherokee Forum 2 10-10-2008 06:04 AM
Draining WJ Radiator Mark960 ZJ Grand Cherokee Forum 4 06-07-2008 06:38 AM
something draining battery? Trev97 ZJ Grand Cherokee Forum 10 08-31-2007 08:47 PM
Draining Radiator mmiller ZJ Grand Cherokee Forum 4 07-08-2004 02:25 PM
