Radiator Leak 96 ZJ 4L - JeepForum.com
post #1 of 6 Old 08-25-2013, 02:46 PM Thread Starter
kawegit
So I got this 96 ZJ limited 4.0L and I am not sure where this coolant leak is coming from. I have heard that a pretty typical problem is the metal on plastic construction causing people to replace the radiator with a better, all metal radiator. The leak is significant, losing about 1/4 to 1/2" of fluid in the reservoir whenever I drive it 10 or so miles. I have searched and the leak appears to be coming from the radiator itself as the only place I can see it is beneath the radiator from the center to passenger side, where it pools on the lip of metal behind the bumper and then drips to the ground. All the hoses are dry and the service receipts in the glove box show they have all been replaced about 20k miles ago. Does this sound like the need for a new radiator? I'll try to get some pics but it is hard to see as the only place fluid is really visible is beneath the radiator. Also, there is some discoloration, sort of a "whitening", on the upper passenger side of the core. Is this corrosion?
kawegit is offline
post #2 of 6 Old 08-25-2013, 03:12 PM
Oldfrog
2007 WK
Probably. Drive it, to get up to operating temp, then kill it, pop the hood and take an LED flashlight to help see the leak while it's still under pressure. If you still have the original radiator, you have been lucky. Replace it. They arent expensive.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #3 of 6 Old 08-25-2013, 05:05 PM
shaban
And by the way, beware, there are all-metal chinese radiators made by Silla, they're cheap (around $140) and generally OK but require a fair bit of hacking to install.
I had to cut my fan shroud to make it fit.
shaban is offline
post #4 of 6 Old 08-25-2013, 06:31 PM Thread Starter
kawegit
Looking at a csf all metal. I haven't seen any bad reviews on them at it seems a reasonably priced upgrade.
kawegit is offline
post #5 of 6 Old 08-26-2013, 09:15 AM
Octotat
I had the same exact kind of leak and never could find it. I put in this Silla radiator and it's worked great! But like this post mentions, you will have to cut some of the fan shroud away.
Octotat is offline
post #6 of 6 Old 08-26-2013, 09:39 AM
AVR2
I have a stock-type replacement rad from Silla, bought through Radiator Express. It dropped straight in and has been working fine for the last year. The only issue was sourcing my own fitting for the trans cooler pressure line; there were a handful of fittings included with the rad, but none were right for my application.
AVR2 is offline
