Radiator issue 1997 - JeepForum.com
post #1 of 5 Old 06-18-2013, 10:29 AM Thread Starter
bigislandhikers
1989 XJ Cherokee
Radiator issue 1997
Got a call from my daughter that she had a radiator hose blow off. When I got there the top hose had indeed come off. I noticed that the small raised ring on the inlet nozzle had snapped off cleanly. Seems like the clamp wasn't real tight either. I replace the hose and topped off the fluid.
Started up fine and I drove about 10 miles and it held together.
Am I looking at a new radiator or can it get by without this ring to hold the hose on? Maybe use two clamps instead of one?
Another question dealing with this. It was definitely low of fluid but the overflow container was at a normal level. Any guess why this would be?
Thanks
BIH
bigislandhikers is offline
post #2 of 5 Old 06-18-2013, 10:36 AM
PolkaPower
The overflow container rises and falls according to the motor temp. I would go ahead and replace the radiator. Even with 3 clamps on there it would worry me since that will leave you stranded. Also it appears that the plastic is weakened. It could happen again.
PolkaPower is online now
post #3 of 5 Old 06-18-2013, 11:06 AM
OldManTan
You may have bigger problems that just a shetty worm clamp.
Was the truck running hot before the hose blew off? Mine got to around 230-240 before this happened...
further investigation showed me that my clutch fan was shot and my radiator was in piss poor condition.
new radiator and e fan swap did the trick for me.
haha
hope you dont have to make such a drastic fix.
OldManTan is offline
post #4 of 5 Old 06-18-2013, 12:19 PM Thread Starter
bigislandhikers
1989 XJ Cherokee
haha
She said it wasn't running hot at all. I drove it this weekend and it was below 210 to whole time, even with the air on.
post #5 of 5 Old 06-18-2013, 05:34 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Yeah if the pressure snapped that off I would replace the radiator. Is it the original one? Mine did the thing with the coolant bottle once. A brand new radiator cap was bad and didn't allow the fluid to enter the radiator in the cool down cycle. Replaced the cap and all was well. Kinda sounds like in a way your cap is bad.
Originally Posted by HighLonesome
coralman is offline
