radiator install question - JeepForum.com
post #1 of 3 Old 09-04-2012, 05:31 PM Thread Starter
tylersjeep
1994 ZJ
I just bought a radiator from auto zone cause the one I put in from the junkyard is leaking, I notices there's pegs on the bottom of the new radiator and there where no pegs on the old radiator. now before I install this I need to know if there are pegs holes for the radiator or do I need to return this. oh its on a 1994 grand cherokee 5.2.
tylersjeep is offline
post #2 of 3 Old 09-04-2012, 06:45 PM
LouC
2007 WK
There are supposed to be pegs...
LouC is offline
post #3 of 3 Old 09-04-2012, 06:56 PM
AVR2
Yes, there should be two dowels on the bottom of the rad which fit into two holes in the crossmember underneath. Actually they fit through mounting holes in the brackets on the bottom of the AC condenser and then go into the crossmember. Maybe the old ones broke off and are still in the holes?
You also want to make sure that the rubber grommets for the holes are still there. If they aren't the rad won't be fully secure and can rattle. The radiator grommets cost a fortune from the dealer but I got a pair for about $20 on eBay (no JYs around here for me to check).
AVR2 is offline
ZJ radiator install, best spark plugs, bumper guard install doccjp ZJ Grand Cherokee Forum 10 09-30-2010 07:20 PM
Radiator/water pump install question lma1973 ZJ Grand Cherokee Forum 3 07-12-2007 08:05 PM
radiator install Nick ZJ ZJ Grand Cherokee Forum 31 03-17-2006 11:17 PM
Radiator install anticrombie ZJ Grand Cherokee Forum 0 12-13-2005 03:28 PM
Radiator install?!? mattklaman ZJ Grand Cherokee Forum 1 08-14-2005 08:04 AM
