Radiator drain valve? 93 ZJ 4.0 - Page 2 - JeepForum.com
post #16 of 20 Old 06-11-2007, 02:35 PM
ajmorell
ajmorell's Avatar
Originally Posted by driabyor
Yes I do.... I just came in from working on it. Spent about an hour getting things ready. Did about 15 minute of actual work on the Jeep. Now minus the shroud, fan and belt.
Now off to Orielly's
Yep, just pointing out that was probably why your drain was on the driver's side of the radiator. The drain-cock on the 4.0 is on the passenger side.
ajmorell is offline
post #17 of 20 Old 06-11-2007, 02:38 PM
driabyor
driabyor's Avatar
1994 ZJ
I suppose the 5.9's is in the middle
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #18 of 20 Old 06-11-2007, 05:18 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Thanks for pointing that out. I thought they were both on the passenger's side
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #19 of 20 Old 06-11-2007, 07:00 PM
ajmorell
ajmorell's Avatar
Probably!
ajmorell is offline
post #20 of 20 Old 06-04-2013, 10:40 AM
Roselink303
1993 FSJ Cherokee
On passenger side, push front headlight cover up. On the radiator about 2 inches up you will see a toggle shaped plug. Unscrew to open. Easy as pie.
No replacement parts.
Green coolant. DO NOT use water by itself during the flush. That is like de-seasoning a cast iron skillet.
My lower hose is metal; I can't disconnect it without damaging it.
Roselink303 is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 12:18 PM
Radiator Drain Plug - 4.7L WJ thoscos ZJ Grand Cherokee Forum 6 01-07-2009 07:07 AM
Radiator Drain Plug UltimatE ZJ Grand Cherokee Forum 1 09-20-2007 01:58 PM
radiator drain cock automan25 ZJ Grand Cherokee Forum 2 09-18-2004 12:17 PM
Radiator drain petcock HardStepper ZJ Grand Cherokee Forum 4 09-06-2004 10:37 AM
