Radiator drain valve? 93 ZJ 4.0 - JeepForum.com
post #1 of 20 Old 06-11-2007, 09:32 AM Thread Starter
lawdogg
I did some searching on here about changing out my radiator.
I have a few questions still:
1. The haynes manual says the radiator has a drain plug somewhere - I can't find it! There is a plastic shroud under there, do I need to take this off?
2. From searching, I found that you guys just unscrew the compression fittings on the rad itself instead of dealing with the weird fittings on the trans cooler lines - is this true? If so, how do you get to the compression fittings at the radiator? Remove all that crap under there first?
Thanks!!
-Ryan
2002 WJ 4.0 - Blue Jeep Club #255 (totalled by drunk driver)
1994 3000GT VR-4 (11.8 @ 116, 17psi, pump gas & street tires)
lawdogg is offline
post #2 of 20 Old 06-11-2007, 09:42 AM
ajmorell
ajmorell's Avatar
I'm not sure on your second question, but the drain plug is on the lower passanger side of the radiator. I can't remember if you need to remove the shroud or not since mine hasn't been on in a while. It is plastic and just unscrews. This will drain the radiator, but not the engine block.
ajmorell is offline
post #3 of 20 Old 06-11-2007, 09:44 AM Thread Starter
lawdogg
Thanks - I'll take that shroud off today and see if I can find it. Not interested in draining the block since I'm just changing out the radiator.
lawdogg is offline
post #4 of 20 Old 06-11-2007, 09:52 AM
micifus
Original GC'er
micifus's Avatar
If you have the factory skid its a real PITA, I would suggest getting Radiator Flush Kit by prestone. It will make draining your radiator 100 times easier and all you to flush out a lot of junk by having water run through your system via a garden hose.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #5 of 20 Old 06-11-2007, 09:53 AM
ajmorell
ajmorell's Avatar
Just thought I'd let you know in case you were doing a flush and fill. You should just remove the shroud anyways as you will probably need to in order to remove the radiator.
ajmorell is offline
post #6 of 20 Old 06-11-2007, 09:59 AM Thread Starter
lawdogg
Thanks! I appreciate it. It kinda bugs me that with a billion times more room in the engine bay than I'm used to, it's still a PITA to work on the damn thing!!
I'll take off that shroud and see if it clears things up at all - hopefully I'll find the drain on the passenger side and be able to take off those tranny cooler lines at the radiator with some wrenches -- another question: I assume those tranny cooler lines will leak tranny fluid when I take em off. Can I fill the tranny from the engine bay or will I have to fill it from below the Jeep?
lawdogg is offline
post #7 of 20 Old 06-11-2007, 10:15 AM
micifus
Original GC'er
micifus's Avatar
never mind
32"x11.5" BFG A/T
4" Lift
micifus is offline
post #8 of 20 Old 06-11-2007, 10:20 AM
micifus
Original GC'er
micifus's Avatar
The lines will leak very little if at all, I did not have to add any fluid after my rad change but if you do you can fill it from the top.
32"x11.5" BFG A/T
4" Lift
micifus is offline
post #9 of 20 Old 06-11-2007, 11:06 AM Thread Starter
lawdogg
Thanks for the help. With any luck I'll report back successfully tomorrow.
lawdogg is offline
post #10 of 20 Old 06-11-2007, 01:00 PM
greasefingers
greasefingers's Avatar
1994 ZJ
If you can not find the drain-cock then you still have to remove the lower hose to replace the radiator, so that is how I would drain it. You might want to replace the upper & lower hoses as well?
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #11 of 20 Old 06-11-2007, 01:35 PM Thread Starter
lawdogg
Well the only reason I'm trying to do it neatly is because I'm technically not allowed to do this in my parking lot. If I so much as drip coolant on the pavement, the old lady next door will flip because her dumb little lapdog will lick it and die. Then I get kicked out.
But yeah, that's how I'll do it if I can't get to the drain.
lawdogg is offline
post #12 of 20 Old 06-11-2007, 01:46 PM
greasefingers
1994 ZJ
Ok just lie on your back and look up yet behind the lower splash guard. Itís hiding up in there at the bottom of the radiator (passengerís side) and of course the engine side of the rad. You will need a 16 in long piece hose approximate inner diameter (3/8Ē) to slip onto the drain cock with the splash guard in place.
Cheers Steve
post #13 of 20 Old 06-11-2007, 02:03 PM
driabyor
driabyor's Avatar
1994 ZJ
mine is one the lower left, driver's side. And man does it make a mess. I'm in the process of dewaterpumping it.
I can't believe it only lasted about 150,000 miles
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #14 of 20 Old 06-11-2007, 02:06 PM
ajmorell
ajmorell's Avatar
You also have a 5.2
ajmorell is offline
post #15 of 20 Old 06-11-2007, 02:26 PM
driabyor
driabyor's Avatar
1994 ZJ
You also have a 5.2
Yes I do.... I just came in from working on it. Spent about an hour getting things ready. Did about 15 minute of actual work on the Jeep. Now minus the shroud, fan and belt.
Now off to Orielly's
5.2 liter 242 :)
driabyor is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 12:18 PM
Radiator Drain Plug - 4.7L WJ thoscos ZJ Grand Cherokee Forum 6 01-07-2009 07:07 AM
Radiator Drain Plug UltimatE ZJ Grand Cherokee Forum 1 09-20-2007 01:58 PM
radiator drain cock automan25 ZJ Grand Cherokee Forum 2 09-18-2004 12:17 PM
Radiator drain petcock HardStepper ZJ Grand Cherokee Forum 4 09-06-2004 10:37 AM
