Radiator drain plug leak - JeepForum.com
post #1 of 12 Old 05-31-2009, 08:50 PM Thread Starter
falco84
Just noticed coolant coming out from the radiator drain plug. Tried tightening it, but the bolt just keeps on spinning (is it supposed to do that?), and the coolant continues to leak out slowly. How can I fix this?
falco84 is offline
post #2 of 12 Old 05-31-2009, 09:01 PM
xJoshxx
2012 WK
slip a piece of hose over it clamp it on the drain the stick a bolt in the end of tube problem solved
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 12 Old 05-31-2009, 09:48 PM
phitmein
phitmein's Avatar
Josh, I like the way you think, that is a very good idea for a fix ...
I, like you, think that the leak is coming out the outlet hole, but it does bother me the he said that the bolt seems to just spin without tightening, but if it was me, I would try your fix first ...
Phit
phitmein is offline
post #4 of 12 Old 05-31-2009, 10:44 PM
Sandy R
Replacements are not expensive.
Sandy Reshes
95 4.0 built for the rocks ZJ Laredo with Clayton's longarms, some cool ARB stuff
Every GSW since it started in 1998
2005 Rubicon Unlimited
Sandy R is offline
post #5 of 12 Old 05-31-2009, 10:45 PM
xJoshxx
2012 WK
either is tubing and bolt
2011 WK2 ORA2 sold
xJoshxx is offline
post #6 of 12 Old 05-31-2009, 10:54 PM Thread Starter
falco84
That's a good temp fix with the tubing. I may have to go with that until I flush the system and have a chance to take a better look at the plug.
I've never taken out the drain plug, so I am not sure what's there and what needs to be replaced. I hope the thread in the radiator is not stripped.
falco84 is offline
post #7 of 12 Old 05-31-2009, 10:57 PM
phitmein
phitmein's Avatar
And you do not have to drain the fluid ...
If the hose worked, then I would use it until I went to replace the fluid and then do the repair ...
But really, knowing me, if the hose worked, then I would just go by the old adage of " If it ain't broke don't fix it" ...
phitmein is offline
post #8 of 12 Old 05-31-2009, 11:26 PM
phitmein
phitmein's Avatar
Also, you may not need the clamp. Just the hose and the plug/bolt may fix it ...
And it poises an interesting question to me ??? Would rad. pressure be involved or would be more like a drip???
I'm thinking drip and just for my own education, I would go without the clamp, just to see how that worked ...
Also, when you go to do a fix, buy a can of the cheapest ether/starting fluid that you can find and spray down all that wet area and it will give you a clean playing field, for when you look back at it again, to see if it is fixed .
Make sure to get the cheap stuff, because it does not have upper end lubricant in it, and you want it clean not with a oily residue on it .
I love ether/starting fluid and have used it many a time when working on nasty stuff ...
phitmein is offline
post #9 of 12 Old 05-31-2009, 11:28 PM
xJoshxx
2012 WK
Sounds like you use it a closed area haha
2011 WK2 ORA2 sold
xJoshxx is offline
post #10 of 12 Old 05-31-2009, 11:28 PM
Mickey_D
Just no smoking...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #11 of 12 Old 06-01-2009, 12:02 AM
phitmein
phitmein's Avatar
The truth be told here guys ... The smoking works just fine for me thank you very much ...
phitmein is offline
post #12 of 12 Old 07-13-2009, 06:26 PM Thread Starter
falco84
Well, it turned out that the coolant was coming out from more than just the drain plug. That entire corner was leaking, so I had the radiator replaced with a new one. The entire bottom half of the original had disintegrated after 250,000km.
falco84 is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 01:18 PM
Radiator Drain Plug - 4.7L WJ thoscos ZJ Grand Cherokee Forum 6 01-07-2009 08:07 AM
Radiator Drain Plug UltimatE ZJ Grand Cherokee Forum 1 09-20-2007 02:58 PM
Radiator Drain plug?????? Decipticon ZJ Grand Cherokee Forum 8 08-27-2005 05:15 PM
Radiator Drain Plug Going Bad? dpierson ZJ Grand Cherokee Forum 1 07-27-2005 01:08 PM
