Radiator Drain Plug - 4.7L WJ - JeepForum.com
post #1 of 7 Old 01-03-2009, 05:56 PM Thread Starter
thoscos
Hi all,
I have read through a lot of the the old threads but can't find the answer I'm looking for.
I flushed my cooling system today. I started by turning the drain plug. Its only turns 1/4 turn and no fluid comes out ... Ended up just pulling the bottom radiator hose. So how does that drain really work? does it pop out or something? I cant remember if it was turned to clockwise or counter clockwise to begin with. My concern is that I may have it turned the wrong way and it may pop out or start draining while I'm driving.
Does turning it clockwise or counter clockwise lock it in place/closed??
Thanks
2003 Grand Cherokee Overland 4.7HO- sold
2002 Grand Cherokee Overland 4.7HO
2003 4-Runner 4.7
thoscos is offline
post #2 of 7 Old 01-03-2009, 06:10 PM
jeremy18
It turns a fourth a turn or a half cant remember exactly but then you should be able to pull it out. ITs kinda of a plastic cork lol
99 WJ Black on Black on Black
4.7L V8,20x10 Wheels,33/12.50/R20 Nitto Muddgraplers,6.5" IRO Long Arm Kit,Flowmaster 50 SUV Series Exhaust,4 10" Memphis M3 Sub's In Slot and Port Box,2000 watt Memphis Bell Amp,300 Amp Alterantor,Memphis Amp Kit,5% Tint All The Way Around,Black Projector Lights,Black Projector Fog Lights
jeremy18 is offline
post #3 of 7 Old 01-06-2009, 08:43 AM Thread Starter
thoscos
Jeremy18,
Thanks for the reply. That helps for the next time I need to drain the radiator.
Which way do you turn it to lock it in place?
Thanks
2003 4-Runner 4.7
thoscos is offline
post #4 of 7 Old 01-06-2009, 10:20 AM
WJChris
WJChris's Avatar
I have tried to remove that damn plug on 2 different Jeeps/motors. I never got coolant to come out.
I gave up and pulled the hose as you did.
I think they overdid the draincocks. Its obviously designed for rocket scientists.
WJChris is offline
post #5 of 7 Old 01-06-2009, 10:56 AM
AgitatedPancake
if your talking about the petcock valve with fill nipple, just twist counter clockwise wile pulling out to make it release fluid (pulling out after the twise is what allows water through), then opposite to close it back up. I broke mine =/
To contact me, email
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread:
AgitatedPancake is offline
post #6 of 7 Old 01-06-2009, 03:07 PM
jeremy18
Yea after a small turn counter clockwise it will stop turning after that just pull it off. Dont get burned. Cause that fluid is hot. Use some pilers works best
jeremy18 is offline
post #7 of 7 Old 01-07-2009, 07:07 AM Thread Starter
thoscos
I'll check to see if its turned clockwise to make sure its closed.
Thanks,
2003 4-Runner 4.7
thoscos is offline
Radiator Drain Plug? Coolant wont drain epfriis ZJ Grand Cherokee Forum 6 06-18-2015 12:18 PM
Radiator drain plug leak falco84 ZJ Grand Cherokee Forum 11 07-13-2009 05:26 PM
Radiator Drain Plug UltimatE ZJ Grand Cherokee Forum 1 09-20-2007 01:58 PM
Radiator Drain plug?????? Decipticon ZJ Grand Cherokee Forum 8 08-27-2005 04:15 PM
Radiator Drain Plug Going Bad? dpierson ZJ Grand Cherokee Forum 1 07-27-2005 12:08 PM
