Quantcast Quick Valve cover question. - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Quick Valve cover question.
Old 04-03-2008, 05:19 PM   #1
Windowsrookie
I snapped off one of the bolt heads when changing my Valve cover gaskets today. Will it still seal ok?
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive
1987 Wrangler 4.2L
Windowsrookie is offline   Reply With Quote
Old 04-03-2008, 05:42 PM   #2
nashmd454
I would venture to say not entirely well.
96' JGC V-8 5.2L ltd.
way too much to list.
Thought for the day:
If GOD gave HIS only son for us...can't we at least give HIM an hour of our time a day.
[URL]http://photobucket.com/albums/v639/nashmd454[/URL]
[url]http://groups.jeepforum.com/The_Dark_Side[/url]
nashmd454 is offline   Reply With Quote
Old 04-03-2008, 06:43 PM   #3
Windowsrookie
I just ran the engine up to temp and didn't spot any leaks. It's a rubber Fel-Pro, If I spot any leaks later can I just use an easy out and pop a bolt in?
1987 Wrangler 4.2L
Old 04-03-2008, 07:04 PM   #4
Windowsrookie
On second thought, Is it safe to keep in there? It won't fall into the engine will it?
1987 Wrangler 4.2L
Old 04-03-2008, 07:07 PM   #5
ajmorell
ajmorell's Avatar
I'm confused on what broke exactly. Did it break down when you were tightening it?? If it is threaded it shouldn't fall out at all.
Andy
'98 Jeep ZJ "Pearl"
ajmorell is offline   Reply With Quote
Old 04-03-2008, 07:09 PM   #6
Windowsrookie
Yes, the head broke off of the bolt when I tightened it. So most of it is stuck in the engine.
1987 Wrangler 4.2L
Old 04-03-2008, 07:15 PM   #7
sandman
so how would that fall out in your engine?
try an easyout. or a reverse drillbit.
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
Old 04-03-2008, 09:26 PM   #8
Vestjam
Vestjam's Avatar
.... and be careful to not over-torque the bolts.
If you pull the valve cover off, there should be enough of the bolt shaft left to grab hold of with a vice grip or something so you can remove and replace with a new one.
2008 Jeep Wrangler X (Hard Top)
Incubus Off Road 511's with BFG 285/70-17
1998 Jeep Cherokee Sport
4.0L/AW4, Yakima Roof Rack
Vestjam is offline   Reply With Quote
Old 04-03-2008, 09:29 PM   #9
-Joe-
Invest in a torque wrench and manual..
they arent to be very tight..
althought i hate removing the 4.0s valve cover.. hopefully the v8 is easier
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline   Reply With Quote
Old 04-03-2008, 09:33 PM   #10
Windowsrookie
I have a Haynes manual, and a torque wrench. Torque wrench was set for 10ft-lbs. I guess it's time for a new one.
I went out and loosened the bolts a little, I think I was tightening them down too much.
I think I'll just let it be for now, if it starts leaking I'll take an easy-out to it. It's on the passenger side Valve cover, and I had to remove the A/C compressor to get the lines out of the way in order to remove it.
1987 Wrangler 4.2L
Old 04-03-2008, 09:44 PM   #11
-Joe-
Get a smaller one.. i have one that does 10 - 180 ft pnds and another that does 0 - 80..
valve cover bolts are about 7 ft pounds
- Joe -
Glock Forum
