Quick Help Needed. .. . What do these go to?? - JeepForum.com
post #1 of 20 Old 01-30-2013, 11:49 AM Thread Starter
JeepBeats96JGC
Hello everyone, so, im under the hood installing a new HO Alt and a new battery and decided to also clean up the wiring to my amplifiers..
First i noticed a plug not going to anything near the battery tray, it's a single brown wire, im 99.9% sure it was not connected before i pulled the battery out.
Then i noticed a plug that is ran under the PCM not going to anything. This plug is a black and red wire and on the plug it says PED 42 and where the wires connect to the plug it says A & B. I am also 99.9% sure this was unplugged before i did any work on my jeep today because i was nowhere near this area until i looked for a better way to route my amp power cables.
I don't notice anything not working that should be when i drive the jeep (prior to doing the work today)
4.0 Motor**
Any help is greatly appreciated, and sorry about picture size in advance :X
JeepBeats96JGC is offline
post #2 of 20 Old 01-30-2013, 11:57 AM
OverlandZJ
Guessing here..
Hood light and batt temp sensor?
OverlandZJ is offline
post #3 of 20 Old 01-30-2013, 12:02 PM Thread Starter
JeepBeats96JGC
Originally Posted by OverlandZJ View Post
Guessing here..
Hood light works.
Where would the BTS plug in? I can't seem to find the location. Thx for your reply!
post #4 of 20 Old 01-30-2013, 12:09 PM
OverlandZJ
Coolant level sensor then?
Under the batt tray. Just looked at my 98.. it's a two wire to batt tray and i dont see a single brown wire anywhere near.
post #5 of 20 Old 01-30-2013, 12:13 PM Thread Starter
JeepBeats96JGC
Hmmm, this single wire is coming out of the same split loom as the ground cables grounded to the inside of the fender area. gona go snoop around some more. Thx again for the reply.
post #6 of 20 Old 01-30-2013, 02:13 PM Thread Starter
JeepBeats96JGC
No one else has any ideas?
post #7 of 20 Old 01-30-2013, 02:54 PM
carrasaurus
Kinda looks like the coolant sensor plug, but that's not near the battery. Is there a plug at your coolant reservoir?
carrasaurus is offline
post #8 of 20 Old 01-30-2013, 02:58 PM Thread Starter
JeepBeats96JGC
pretty sure i saw a plug near the coolant res. plugged in. Is there another one under it? I didnt take the res out to look.
post #9 of 20 Old 01-30-2013, 03:40 PM
carrasaurus
No. It plugs into the cap on top of the reservoir.
post #10 of 20 Old 01-31-2013, 01:08 PM Thread Starter
JeepBeats96JGC
Bump. Maybe someone that didn't visit the forum yesterday knows what these are and where they go? Been driving the jeep around and no new issues. Just bugs me that i know they're there and unplugged!!
post #11 of 20 Old 01-31-2013, 01:25 PM
Oldfrog
2007 WK
I bought my 97 new and that wire has been unplugged since day one as I recall.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #12 of 20 Old 01-31-2013, 01:33 PM
DirtDodd
My 93 has that wire going to and plugging onto a flat that looks like a ground on the underside of the lip of the passenger fender, kinda near the front, beside the battery. Maybe that wire got cut out of use after 95, but remained in the manufacturing of the harness for cost's sake? Idk...
Not enough ZJ experience to guess on that back one.
Good luck!
DirtDodd is offline
post #13 of 20 Old 01-31-2013, 02:16 PM
fast_cobra_427
They are most likely for options you don't have on your ZJ. Pretty sure my 98 has that same one near the PCM not plugged in. If you are 99.9% sure they weren't plugged in before and you have no new issues, then I wouldn't sweat it.
98 ZJ, 4.5" RC Series 2 X-Flex kit, 31x10.50x15 BfGoodrich KM2's, ARB Deluxe Winch Bumper, Factory Skids, JohnBuilt Rock slides, Aussie Locked up front, Mopar Trac-Loc out back
fast_cobra_427 is offline
post #14 of 20 Old 01-31-2013, 04:30 PM
DirtDodd
Ok, kind of scratch my last post. Not a ground on that wire near the battery, but looks like a switch that prob tells the info center whether or not the hood is shut all the way.
DirtDodd is offline
post #15 of 20 Old 01-31-2013, 05:20 PM Thread Starter
JeepBeats96JGC
Thanks for all of the replies everyone! Guess they'll just remain unplugged lol
