Quick ,Double Cardan U joint Ball Spring???????? - JeepForum.com
post #1 of 13 Old 02-06-2012, 06:09 PM Thread Starter
hdrocknroll
Quick ,Double Cardan U joint Ball Spring?? Update
I s there supposed to be a spring in here ,cuz there was not one.
The repair kit at bottom shows one
Neapco Double Cardan CV Ball Seat Repair Kit
Always !! Keep A Firm Grip On Your Tool !!
Watch Out For The Air Hose Gone Wild!! Or Wear A Cup,: True Story
Originally Posted by rooster51 View Post
Whats the worse that can happen? Your jeeps already broke.
hdrocknroll is offline
post #2 of 13 Old 02-06-2012, 06:57 PM
lateralus3
1994 ZJ
yes there is
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #3 of 13 Old 02-06-2012, 07:01 PM Thread Starter
hdrocknroll
Thanks Got the new parts
post #4 of 13 Old 02-06-2012, 07:13 PM
lateralus3
1994 ZJ
did you see these?
http://www.dennysdriveshaft.com/p425...10_series.html
Jacob
post #5 of 13 Old 02-06-2012, 07:15 PM
Nejeep
Yes there is supposed to be a spring in there. Here is a link showing the spring in post #4 and 5 plus a few more rebuild tips.
http://mallcrawlin.com/forum/showthread.php?7478-Double-Cardan-Rebuild
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #6 of 13 Old 02-06-2012, 07:31 PM Thread Starter
hdrocknroll
Originally Posted by lateralus3 View Post
Well thats what I'm going have ,to have ,cuz look at the inside of this ^^^^^
I can get one at Advance For $60.00 with 20 dollar off code.
Thats a lot of money for this little part
Good thing is I may have found my small vibration problem
Now the new girl at the parts store knows my name
Last edited by ratmonkey; 02-07-2012 at 05:34 PM. Reason: DO NOT AVOID THE LANGUAGE FILTER
post #7 of 13 Old 02-06-2012, 10:31 PM Thread Starter
hdrocknroll
Okay here's the other part, there was no rubber boot and this thing.
post #8 of 13 Old 02-07-2012, 09:09 AM
gabrod72
Being in Flint I imagine there's got to be a drive train specialist somewhere near you. I'm in the process of either greasing or rebuilding my front shaft, so I may need that part (don't know yet.) You may want to hold out to get the Spicer part - while you're at it, get the grease-able one too. If you go the Advance route, make sure the part is made in the USA - or you'll be taking a chance at hating foreign steel parts soon enough. If you're in a hurry, you can get a used shaft for around $75 and throw it in for now:
http://www.heightsautoparts.com/
I'm not positive about what length you'll need, but you'd better double and triple check. Sounds like you've got the shorter one like I do and they're harder to find... many JY confuse them as interchangeable for the long ones. For the short one, ask if the weld to weld measurement is around 17 - the longer one is around 20".
gabrod72 is offline
post #9 of 13 Old 02-07-2012, 09:46 AM
speedbucket
damn, i paid that much for just the rebuild kit last year, nice deal
mangled the outer lip pretty good, use a ziptie to hold back the yoke when your putting the last ujoint in, you know what im talking about when you get there
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #10 of 13 Old 02-07-2012, 01:20 PM Thread Starter
hdrocknroll
(mangled the outer lip pretty good, use a ziptie to hold back the yoke when your putting the last ujoint in, you know what im talking about when you get there)
I wish I had read the zip tie trick before I did it, good idea, wish I had thought of it ,It was real tricky getting that pressed back together with that spring tension on it. I have done plenty of U joints but never a double.
Took back the repair kit got the other parts.
I straightened up, cleaned up, dressed up the lip on the drive shaft with a round nose Rotary file in the die grinder. By the time I got done you could hardly tell it was bunged up, worked out real good. Well I had to because I put it all together and was hitting the banged up part and jamming up, but it's all good now.7 new U joints altogether , Just have to take it for drive here in a Little bit to see if I solved the small vibration deal. IDK but it was screwed up enough to cause a vibration.
post #11 of 13 Old 02-09-2012, 10:07 PM Thread Starter
hdrocknroll
I just wanted to get this thing put back together and thought it may work but it was still vibrataing, the end of the driveshaft where the center ball goes was all banged up and I don't know. I guess bent.
Took the shaft off. No vibration picked up the driveshaft at the junkyard $40 put all the new U joints in that driveshaft, put the driveshaft back in,greased her up, put new Timken hubs on the front, changed TC case fluid and she drives like a brand-new Jeep, but her rear is still singing to me.
post #12 of 13 Old 02-10-2012, 01:40 AM Thread Starter
hdrocknroll
PS.
Since the centering yoke ball and spring on the junkyard shaft were in good shape. I did not replace it.
I cleaned it up, pumped it full of grease, there is a hole in the bottom of the ball and a cavity underneath to hold grease.
post #13 of 13 Old 02-10-2012, 08:19 PM Thread Starter
hdrocknroll
How to measure your drive shaft, there are other illustrations for differant types at driveshaftspecialist.com HERE
1 piece Stub/Slip Type shaft with 2 Fixed (bolted on ) Yokes
double cardan u joint , u joints , vibration
WJ: 4.0 Double cardan u-joint driveshaft for under $50 iluvtruenos ZJ Grand Cherokee Forum 1 02-20-2011 03:43 PM
Double cardan joint making noise squashman702 ZJ Grand Cherokee Forum 2 05-29-2009 10:17 AM
Q about Ball joint inside Double Cardon craddock01 ZJ Grand Cherokee Forum 17 05-09-2009 03:23 PM
Double Cardan U-Joint...Removal? Jsun ZJ Grand Cherokee Forum 4 04-30-2008 12:53 PM
double cardan joint driabyor ZJ Grand Cherokee Forum 4 09-11-2005 05:49 PM
