Quick compatibility question, axle housing - JeepForum.com
post #1 of 11 Old 04-28-2007, 09:21 AM Thread Starter
UFO
UFO's Avatar
Need entire axle housing, will the dana 30 from a cherokee work? I believe the year is early 90s.
Rig: 1995 JGC 5.2L V8 Limited 129K Installed: 4.25" (Rusty's 3" coils and 1.75" spacers, removed stock spacer) with 32x11.5R15 Pirelli "Scorpion A/T's" on Cragar "Soft 8's" || Rusty's Adj. Front UCAs and LCAs, Adj. Front Trackbar, Shocks and Steering Stab. || Kevin's Adj. Rear Trackbar || R.E.'s Extended Swaybar Links w/ conversion kit
UFO is offline
post #2 of 11 Old 04-28-2007, 10:09 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
forget the danas, put something better under there.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #3 of 11 Old 04-28-2007, 10:33 AM Thread Starter
UFO
UFO's Avatar
Im getting the cherokee for near free
UFO is offline
post #4 of 11 Old 04-28-2007, 11:13 AM
legend6009
legend6009's Avatar
try to get a 44 out of a waggy...and have that put in if your going to change it out, might as well put a stronger one in....but ifd not i believe it would work not sure though
-Andy-
06-tj-2.4 4 cyl, 6 speed. red, 2.25 bb on 31s, rear aussie locker, hella 500 series on bumper, mile marker pe8000, rock krawler rear bumper w/ hitch, optilux lights mounted on stainless steel windshield light brackets, in cab winch switch
red jeep club member 479
my myspace^
legend6009 is offline
post #5 of 11 Old 04-28-2007, 03:48 PM
anticrombie
anticrombie's Avatar
As long as you get the carrier and ring and pinion, it'll bolt in. It'll also be a bolt in for the zj as well as be stronger than stock because it's the hp30.
People need to stop talking out their rears.
Charlie
anticrombie is offline
post #6 of 11 Old 04-28-2007, 04:30 PM Thread Starter
UFO
UFO's Avatar
I forgot though, I'm running tow gears (3.73), isn't that going to have problems, or is gearing in the front not going to be a problem? What gears are going to be running in the d30 on the cherokee?
UFO is offline
post #7 of 11 Old 04-28-2007, 07:10 PM
anticrombie
It is possible that it'll have 3.73, but that was rare. It more than likely either has 3.55's or 4.11's. Look at the tag, but if it does have it then you're good to go.
Charlie
post #8 of 11 Old 04-29-2007, 12:09 AM
legend6009
legend6009's Avatar
you know i was reading over at the xj forum...they do have xjs that ran 4.56 gears..i was like wha..wha..whattt??...grands should have them
-Andy-
my myspace^
post #9 of 11 Old 04-29-2007, 06:33 AM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Gents,
he's right about both things. The HP30 and you guys spreading bad info.
Hunter
04 4.7 HO, limited
04 4.7 HO, Overland
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #10 of 11 Old 04-29-2007, 06:41 AM
rdrbssr11
that's where i got my HP30 from, it made the swap pretty cheap since i didn't have to re-gear two axles.
-95' grand cherokee w/ 5.2. ARB & xd9000. IRO 4.5" w/ 33's. 8.8 & HP 30 w/ 4.10's both aussie locked and some other goodies.
-97' grand cherokee w/ 4.0. stock.
rdrbssr11 is offline
post #11 of 11 Old 04-30-2007, 11:11 AM Thread Starter
UFO
UFO's Avatar
Well the plan fell through, my friend ended up selling the cherokee for a good price, so I'm happy for him anyway.
I did find this though, I know the control arm bracket is messed, but the question still holds, will this be compatible (read: bolt up) to a zj?
http://cgi.ebay.com/ebaymotors/Dana-...ayphotohosting
UFO is offline
Axle/Hub Compatibility rnrkid ZJ Grand Cherokee Forum 5 06-01-2009 10:28 AM
axle quick question cmonson ZJ Grand Cherokee Forum 6 06-17-2008 09:24 AM
Quick question about ZJ axle CV joints senny623 ZJ Grand Cherokee Forum 16 04-02-2007 07:39 AM
Quick D35 axle shaft question OH-ZJ-IO ZJ Grand Cherokee Forum 2 07-10-2006 08:29 AM
axle compatibility mythic ZJ Grand Cherokee Forum 9 02-23-2006 09:19 AM
