Quick BB question - JeepForum.com
post #1 of 4 Old 01-26-2005, 04:51 PM Thread Starter
MidniteSquirrel
Quick BB question
Is there anything that needs to be done after putting on a BB? I figure bigger tires would mean the speedometer needs to be set right. things like that... but that's with the tires.
Just wanting to know if lifting it up 2" means some minor adjustments anywhere
2002 WJ - I6
BB+UC 3.5" lift | K&N FIPK | Armor/Tow points |
265/75R16 Cooper Discoverer S/Ts
MidniteSquirrel is offline
post #2 of 4 Old 01-26-2005, 05:35 PM
ben_wagner
ben_wagner's Avatar
1994 ZJ
With 2" you may want to consider getting new shocks, as well. The stock ones (I am assuming you have stock) will be stretched out further and will wear out faster. Plus, depending on your miles they may need replacing anyway. Around 100,000 miles is a good time to get new ones.
ben_wagner is offline
post #3 of 4 Old 01-26-2005, 07:04 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Get an alignment.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #4 of 4 Old 01-26-2005, 07:19 PM
midwest97gc
Alignment is #1- your wheels might end up with positive camber and/or toe-in or toe-out.
While doing the BB you should put new shocks, degrease all of the suspension components, make sure everything is nice and tight.
After my BB, I degreased the suspension/wheelwells and I took a can of flat-black spray paint to it and it looks like all new stuff down there!!!
I also re-greased the fittings on the rod ends... basically anything that had grease from the factory.
Cassius
Platinum 97 GC LTD
2" BB, Edelbrock Shocks, 31X10.5 A/T MT's on Stock Rims, Bump Extensions, Custom Skid Plates, De-pinstripped, De-badged, 5% tint ALL the way around, Yellow top battery, Grounding Kit, 200 Amp Alternator, (6) 10in JL Audio WO's, (2) JL Audio Slash 1000/1 Amps, Alpine IVA-D300 Headunit, MB Quart mids and highs all the way around, and the volume always at 100
JOIN
TODAY - FIGHTING TO LEGALIZE MARIJUANA FOR RESPONSIBLE USERS
midwest97gc is offline
quick rim question..? peicherokee ZJ Grand Cherokee Forum 3 11-19-2009 12:34 PM
Quick Quick Quick....Front DS U Joint Removal Darthteddy ZJ Grand Cherokee Forum 3 08-11-2008 12:25 AM
quick question wranglerswrock ZJ Grand Cherokee Forum 3 08-03-2008 11:57 PM
Quick question... 95ZJ-tilshedies ZJ Grand Cherokee Forum 6 02-27-2008 07:58 PM
Quick Quick Question - Mopar CCC Darthteddy ZJ Grand Cherokee Forum 4 12-05-2007 11:40 AM
