Questions on TB - JeepForum.com
post #1 of 8 Old 05-10-2013, 10:40 AM Thread Starter
CanaanTSA5
Questions on TB
Quick intro, lately when I start my Jeep in the morning I have to let it run for about a minute then shut it off and start it up again for it to run smooth(ish). Otherwise it sounds like it's gunna choke it self to death.
I want to start with the smaller things but Engines are not my forte. My first project will be cleaning the IAC and my TB. My main concern is that this is my DD and I live alone, so I can't **** anything up or I am screwed. So I don't want to get myself in too deep.
I have read the "How to clean your idle air control valve" thread, so that's been my starting point. 3 question on where things are and whatnot.
1. On Image 01, how do I get this out, do I just pull it?
2. On Image 02, That is the TB dirrectly below the giant tube, right? (Go ahead, Laugh)
3. On Image 02, IAC..Correct? (Highlighted)
My expertise is computers, so thanks for bearing with my lack of mechanical knowhow..
1998 ZJ 4.0 Stock 225/75R15 General Grabber AT2
191,000mi
CanaanTSA5 is offline
post #2 of 8 Old 05-10-2013, 11:27 AM
PolkaPower
It's just a plug. You should be able to push on it with your thumb and slide it off. You may need a flat head driver to gently break the dirt seal while you wiggle it but no need to pry it. The TB is under that and that looks like the TPS sensor. The IAC is on the back I think. The front is the MAP sensor.
In this pic the IAC is the one on the left.
PolkaPower is offline
post #3 of 8 Old 05-10-2013, 11:39 AM Thread Starter
CanaanTSA5
Alright. IAC located. But that piece I highlighted in the first picture isn't going to come out without me yanking it..
191,000mi
post #4 of 8 Old 05-10-2013, 11:42 AM
PolkaPower
It's just a plug like all the other sensor plugs. It has a plastic clip that snaps onto the plug. Sometimes they are a pain to get off thats why it's better to slip a flathead driver where the plug and sensor join up and help it a little while you depress the release and wiggle it off.
You can otherwise just remove the screws holding the sensor in and leave it plugged in.
post #5 of 8 Old 05-10-2013, 11:46 AM
PolkaPower
See this thing here in the red circle? That is a button that you depress to unplug this sensor. The TPS and IAC have similar things but they are more like a clip that slides over a notch and hooks on. Try lifting up on it maybe with the flat head while you pull to slide if off.
Look in this link, you can see the little tip where the plug slides over and hooks onto. This is upside down though in the pic. http://4x4point.com.au/cart/images/tps.JPG
post #6 of 8 Old 05-10-2013, 12:06 PM Thread Starter
CanaanTSA5
I was actually talking about something different but I realize after looking at what I was doing a third time, that I was doing something unnecessary.
Very helpful picture in the link, thank you.
Is there anything specific I should be using to wipe off the IAC? Other than the TB Cleaner Spray, as in what implement do I use? Finger, washcloth, towel? I see toothbrush is common. Or if it makes it easier, what should I "not" use.
191,000mi
post #7 of 8 Old 05-10-2013, 12:09 PM
PolkaPower
Depends on how dirty it is I guess. Just be gentle with is and don't open the plunger/sleeve. If you can get the stuff off with a rag you can use that. A toothbrush is probably the best with some carb cleaner.
post #8 of 8 Old 05-10-2013, 12:20 PM Thread Starter
CanaanTSA5
Toothbrush it is then.
This is my project for after work tomorrow. I will post how it goes. Thank you!
191,000mi
