Question on tire size on lifted ZJ..... - JeepForum.com
post #1 of 4 Old 11-09-2001, 06:26 PM Thread Starter
zj4l
If I put a 4.5" Rubicon Express suspension lift with 2" coil spacers, would I be able to fit 33x14 SS Boggers? I'm pretty sure I could fit the 33", but I'm not sure about the width. BTW, this will probably be a 4.0. Thanks
zj4l is offline
post #2 of 4 Old 11-09-2001, 09:04 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
I'm no expert, actually not even close, but I think that you are going to have serious problems running 14" wide tires. You will lose much of you turning radius due to rubbing, and I think that even going straight, the backspacing will be a problem. The Dana 30 in the ZJ is weak. Mine's bone stock, and needed all of the bearings in the axle replaced by 60K miles. Ithink thta your wheel bearings will not live long with such big tires.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 4 Old 11-27-2001, 11:08 AM
RufftyTuffty
RufftyTuffty's Avatar
I argee with CJEEP....
Best stick to the 12.5's. I believe the 14's will probably add too much 'force' to the system and you'll stuggle with clearence's.
Happy Wheelin'
97 V8 TSi 7" RK LA/36s/4.88s/ARBs/TERA 60/8.8/Crane/PSC
RufftyTuffty is offline
post #4 of 4 Old 11-28-2001, 03:47 AM
Brian's 97 ZJ
Brian's 97 ZJ's Avatar
I second CJeep on the Dana as well.
My rear diff needed to be completely (less gears) rebuilt due to the heads breaking off the ring gear fasteners. I'm still puzzled as to how that happened...under no load, normal highway (55mph) conditions.
Dai
For some reason, being a member of the
just isn't as cool... Member #1
Brian's 97 ZJ is offline
Tire Size Question IceZero WK Grand Cherokee & XK Commander Forum 14 12-08-2009 09:18 PM
Lifted WJ owners what size wheel/tire are you running? SomerJeep ZJ Grand Cherokee Forum 11 06-06-2007 10:09 AM
ZJ tire size question NuTone ZJ Grand Cherokee Forum 10 11-19-2006 06:48 PM
Tire size question sharpe84te ZJ Grand Cherokee Forum 2 03-08-2006 06:04 PM
Lifted ZJ: tire size opinions??? kawboy579 ZJ Grand Cherokee Forum 1 09-02-2004 10:14 PM
