Question on Shock/bb combo... newb question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Question on Shock/bb combo... newb question
Jeepforum Coupon for Iron Rock Off RoadRuffstuff Axle Simple Swap Kit!Our Panhard / Trackbar brackets, Variations......
Unread 12-05-2008, 05:47 PM   #1
craig10114
Hey all, my apologies for the newb question, i have searched... havnt found what i was looking for.
I have a 2004 WJ 4.7, and ive started putting a together a modest lift. UC springs, ES9000 Shocks, 2in KOR bb, addco RSB, 265/65/17 REVO's.
My Question...
What should i expect out of this setup. Ride Quality? Off Road performance? Any advice, or do you think i should replace any of those components with anything else?
Thanks again all.
~Craig
oh and heres a pic of the jeep all stock.
craig10114 is offline   Reply With Quote
Unread 12-05-2008, 06:40 PM   #2
lakailimited06
i would ditch the bb+coils and just go straight to 3" or 4" coils..i think you will regret it if you dont. alot of guys that run that setup end up popping their coils out when their front axle droops..it will also give it a somewhat smoother ride if you stick to just coils..
im running a stock rear swaybar with extended endlinks so i cant give my opinion for the addco..
0
with the 3" lift i would go with 31's (minor trimming) or 32's ( alittle more trimming needed)
i have RE monotube shocks and i love them..id definately recommend them..
this setup will give you a good daily driver/offroad combo..also adding JKS front swaybar disconnects will allow more up and down travel for the front when offroad..not a bad idea to look into those..you might also need a JKS adjustable trackbar but every jeep is different..
good luck
99WJ 4.0
IRO 3", SYE, D30 aussie/8.8 aussie, 4.10s, 33's, skids/bumpers
lakailimited06 is offline   Reply With Quote
Unread 12-05-2008, 11:25 PM   #3
craig10114
thanks for the advice, definitely appreciated.. i see your from LI as well, with the offroading we have here... i.e robert moses, and exit 63 on the LIE... what are my chances of popping the coil out?
Unread 12-05-2008, 11:27 PM   #4
Haleyrz
i agree with lakailimited
1998 ZJ Laredo, 4.0L, 2WD "Band Van", Current
1997 XJ, 4.0L, 30x9.50 Maxxis Bighorns, super 44, Sold
2003 WJ Overland, 4.7L HO V8, 6000K HID's, Sold
1996 ZJ Laredo, 5.2L V8, 3" Kolak exhaust, K&N FIPK, 4300K HID's, Sold
http://www.facebook.com/home.php#/pr...27&ref=profile
Haleyrz is offline   Reply With Quote
Unread 12-06-2008, 01:04 PM   #5
lakailimited06
uhh theres really no wheelin on long island...and you definately wont pop a coil out cruising on the beach...i just mean with the bb+uc coil, if your swaybar is disconnected and you're at like max downtravel, your coil will probably pop out..
99WJ 4.0
