Question on mating 242 w/ 545RE. - JeepForum.com
post #1 of 10 Old 07-12-2009, 09:14 PM Thread Starter
JBN311
I picked up a used case at an area junkyard a few months back.
I was just starting to rip out my 247 when my buddy asked where the rest of the threaded studs were that come off the TC. There were only 3 out of 6 mounting studs.
I call them studs because I don't know what they're called. They appear to be a piece of threaded rod that screws into the transfer case then you put the bolts on the remaining threads when mated with the tranny.
Are these "studs" a piece I can get from the dealer?
and
What are they really called so I don't get laughed at when I go buy new ones?
Thanks a lot guys.
Jesse
-Jesse
2004 WJ Laredo V8, NP242 swapped in, front Dana 30 w/ Vari-Lok, Aussie Locked 44a, BB, 30" BFG A/T's, Tow hooks, Rear Hitch, CB, Better than stock radio/MP3 player.
JBN311 is offline
post #2 of 10 Old 07-13-2009, 12:01 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
They're studs. Hope you got a 242hd and not a regular 242.
ratmonkey is offline
post #3 of 10 Old 07-13-2009, 12:27 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Do you have 6 good studs out of the two t-cases?
The nuts seize up often, so the studs become nothing more than bolts.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #4 of 10 Old 07-14-2009, 01:16 PM Thread Starter
JBN311
I might have 6 good ones between the two cases, but I wanted to be safe in case I messed them up while taking them off. I ordered 6 new studs with the nuts. dropped 72.50 on 12 pieces of metal.....oh well, now I just have to find the time to do it......
I did get the HD by the way.
-Jesse
JBN311 is offline
post #5 of 10 Old 07-14-2009, 01:31 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
wow, i would have just cut allthread to length for that kind of money.
post #6 of 10 Old 07-14-2009, 02:48 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
I have extra bolts. I'm sure I can dig up 6 with the nuts NOT frozen to the studs.
It makes it easier to bolt the trans&t-case together, but you only need 3 or 4 to make it line up perfect.
I have replaced 3 transfer cases on WJs and half of the nuts were frozen on the studs. I haven't have any problems just using them as bolts.
post #7 of 10 Old 07-15-2009, 06:35 PM Thread Starter
JBN311
Thanks QuadraTokn,
I prepaid because the stealership needed the money upfront, and they said that since they were special ordering, it was not returnable. Guess I'm out a few dollars. At least I have the right parts.
-Jesse
JBN311 is offline
post #8 of 10 Old 08-01-2009, 10:09 PM Thread Starter
JBN311
***update***
Just got the case in! (finally!) There were no real problems. THe reason I got the thing was because of a whirring noise. (and I wanted an excuse to get the 242) The whirring is still there. I have a QD front axle and the gear oil looked pretty milky. Could the whirring be as simple as a fluid change with a bit of modifier?!?!?!
I could have sworn I changed the fluid days before the noises started........On the other hand I could have driven through water too!
Thanks for the input guys!
Jesse
-Jesse
JBN311 is offline
post #9 of 10 Old 08-01-2009, 10:14 PM
WiCkeDuDe
Usually the whirling is a sign of driveline issue, (u - joints, out balance) or bad pinion or wheel bearings in the axles. Does it change when your on the gas or not?
WiCkeDuDe is offline
post #10 of 10 Old 08-03-2009, 04:00 AM Thread Starter
JBN311
Yep. it happens when I'm on the gas.
-Jesse
JBN311 is offline
Newbiee Question?? - grand cherokee thumping question geoff6194 ZJ Grand Cherokee Forum 2 03-23-2011 01:59 PM
Noise question and Beach wheeling question bimmerjeeper ZJ Grand Cherokee Forum 4 10-06-2008 10:31 PM
air condition face unit question n00b question Fatsooo ZJ Grand Cherokee Forum 4 09-21-2008 08:45 PM
couple minor questions. door question and mirror question Irish_Assassin ZJ Grand Cherokee Forum 2 07-04-2008 02:14 PM
Mating... Engine w/ tranny Vestjam ZJ Grand Cherokee Forum 6 12-17-2006 07:57 PM
