Question From Driving In The Cold - JeepForum.com
post #1 of 9 Old 01-22-2014, 08:52 PM Thread Starter
CanaanTSA5
It's been about 5 degrees the past few days here in New England, not very enjoyable. One thing that bothers me when driving on the highway in the cold is that my gas peddle is much harder to push down than when it is warmer out, even if warmer means still below freezing. Not really one of the areas I know much about, is this a normal occurrence?
1998 ZJ 4.0 Stock 225/75R15 General Grabber AT2
191,000mi
CanaanTSA5 is offline
post #2 of 9 Old 01-22-2014, 09:12 PM
martymars
I haven't noticed that, but I have noticed in general that my Zj doesn't like the cold.
martymars is offline
post #3 of 9 Old 01-22-2014, 09:27 PM
papitt
Having lived in Texas forever .. & Having been a service advisor at Jeep I don;t recall anyone every having that issue. I'd almost say you might want too have another throttle cable installed. Yours might have something inside it helping it freeze up...
.. Put it in neutral and stop.
papitt is offline
post #4 of 9 Old 01-22-2014, 09:40 PM
nnovickzj
sounds like water in the throttle cable i live in mass and havent noticed anything of the sort
97 zj 5.2 40,000mi
locked front and rear, 242, 3.5 iro lift, 32x11.5 kenda klever, 28 laredos for the road
4x 130 watt 6" spots on the roof rack, h3 leds in stock fogs, 2 40w leds on the grill
nnovickzj is offline
post #5 of 9 Old 01-22-2014, 11:38 PM
JohnCrabtree
1994 ZJ
I agree that it sounds like you have something (like water) in that throttle cable that expands when it is cold causing it to seize up.
JohnCrabtree is offline
post #6 of 9 Old 01-22-2014, 11:44 PM
SchizophrenicMC
2016 JK Wrangler
Try cleaning your throttle. Sometimes gunk can harden around it when temperatures drop, making it tougher to actuate.
Signature rules are dumb
SchizophrenicMC is offline
post #7 of 9 Old 01-23-2014, 05:46 AM
LouC
2007 WK
Gunked up throttle plate in the throttle body. I had this on both of our late 80s Toyotas, had to clean them about once every 2 years or so, or else the throttle would get stuck closed in cold weather.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is online now
post #8 of 9 Old 01-24-2014, 07:46 PM
MaintMech
Old and in the way
MaintMech's Avatar
You've got a problem for sure.
-20 here and I've never had that happen.
Everything gets tighter but never had the throttle get hard to push.
When it gets warm in May spray it down with WD-40.
Oh wait, Northeast USA? O.K. next week when it's above freezing.
'96 Grand Laredo, 4.0, Stock, Daily Driver
I fought Oracle and Oracle won!
Originally Posted by coralman
If the faith isn't there,the doubt is.
MaintMech is offline
post #9 of 9 Old 01-29-2014, 11:20 AM Thread Starter
CanaanTSA5
Thanks for all the replies guys. Guess I have a throttle body to go through.
191,000mi
