question about suspension/lift - JeepForum.com
post #1 of 2 Old 08-31-2005, 08:12 PM Thread Starter
2tone93zj
i have a 100% stock 93 grand cherokee with a 6, my suspension is saggy and i was looking into a kit i went with skyjackers base 3 inch lift which includes Front/Rear Coil Springs; Front/Rear Lower Links; Trac Bar Bracket.
the rear springs are a 2" GRAND CHEROKEE REAR CLS
and the fronts are 3"FRONT COILS JEEP. so the question is instead of buying the complete kit can i buy the 3inch front coils, and buy brand new front springs and put them in the rear to save cash?
ALL ADVICE HELPS!!!
thanks
2tone93zj is offline
post #2 of 2 Old 08-31-2005, 08:53 PM
93redzj
yeah you could do a front to rear swap, take the springs from the front and put them in the rear. I think that useally nets you about 3-3.5" of lift. Of course you know you will need other things like shocks and control arms are recommended to be changed at anything over 3" of lift so you might be alright with the stock arms, there might be other things that need changing. check this link out it has a pretty good write up on the front to rear swap but instead of using a 3" spring for the front they use an upcountry spring with a spacer. http://www.4x4wire.com/jeep/tech/susp/frt_bck_swap/
hope this helps
93redzj is offline
VERY IMPORTANT ZJ Lift Suspension Question reelfisher10 ZJ Grand Cherokee Forum 10 02-15-2010 04:45 PM
Suspension lift and tire size question, V32124.23 Mish_Mish WK Grand Cherokee & XK Commander Forum 4 11-23-2008 08:15 AM
Suspension lift question..??? Help Robb_ ZJ Grand Cherokee Forum 5 08-17-2008 06:22 PM
Question about suspension lift. jad_johnson ZJ Grand Cherokee Forum 7 03-22-2007 05:51 PM
suspension lift question blmt98 ZJ Grand Cherokee Forum 2 11-02-2005 06:43 PM
