Question about liftgate glass button? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Question about liftgate glass button?
Rough Country Jeep Suspension Deals at Rockridge 4WD!ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail
Unread 11-01-2014, 07:09 PM   #1
tom5170
My jeep has done this ever since I had it. Every time I use the power locks to unlock the doors, the liftgate glass will unlock at the same time. I was told that this is not normal and that my button for the glass must be stuck.
So today I prayed the mortgage glass button out, took it apart and everything looked right. I put it back together and it's still doing the same thing. So I took it apart again to check and accidentally broke the button so now I need a new one lol. Even with the liftgate button disconnected, the lock on the liftgate glass was still moving each time I unlocked the doors using power locks.
How is the liftgate glass supposed to operate?
tom5170 is offline   Reply With Quote Quick reply to this message
Unread 11-01-2014, 11:44 PM   #2
vlackattack
When you unlock the doors the lift glass should unlock. Then when you push the button it pops open.
vlackattack is offline   Reply With Quote Quick reply to this message
Unread 11-02-2014, 02:12 AM   #3
coralman
I can wish can't I?
coralman's Avatar
You may want to get a jy button. For some obtuse reason Jeep wants $80 for that simple switch. Newer years the price drops dramatically. Aftermarket may offer it somewhere.
http://www.jeepforum.com/forum/f13/c...-faqs-2863665/
coralman is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 01:18 PM   #4
Aceladriver
Originally Posted by tom5170 View Post
..... Even with the liftgate button disconnected, the lock on the liftgate glass was still moving each time I unlocked the doors using power locks.....
It sounds like you're saying the glass actually pops (opens) when you unlock the Jeep?
If so, that's way wrong, lol.
When you unlock the doors the hatch should unlock so you can open it with the handle and the window should be able to open - but only when you press the button.
It should work like that when you unlock the hatch with the key too.
See the pic below. There's a lock solenoid (push/pull motor) but it's behind the panel so it doesn't really show in the pic. You can just barely make out where it's rod connects to the slider though.
When that slider moves by either hitting the unlock button or unlocking the hatch with the key, it closes that square black switch. While that switch is closed there is power to the window relase button.
When you push the window button you complete the circuit through to the window "popper" (square gold thing at the top) which activates and unlocks the window.
So, where you seem to be saying it pops even when the switch is out of the circuit it sounds like the most likely cause is that someone was in there trying to repair it and ended bypassing the square switch and the window button and hot wired the window popper solenoid right into the unlock circuit.
If you compare yours to this pic you might see some wire added in there.
They might have done it to bypass that black switch on the slide, as they've been known to fall off
Happiness is clear in the cab and 150 over 150.
Aceladriver is offline   Reply With Quote Quick reply to this message
Unread 01-08-2015, 03:28 PM   #5
tom5170
hey I know it's been a while lol but where's the unlock circuit
