Question about Drive Shafts.. - JeepForum.com
post #1 of 6 Old 06-02-2004, 09:57 AM Thread Starter
EYPUFF
EYPUFF's Avatar
Umm.. don't really have a lot of time now. But I needed to ask this before I went to work. Anyhow, took my zj into the shop about two weeks ago for a tire alignment and what not. And I was talking to the guy how my car starting shuddering after driving at 70mph for 10 minutes. And he was perplexed, because my jeep is stock. He too has a jeep.. the newer GC.. wj? Anyhow, he told me that it was common for zj's to have problems with their drive shafts. So without hesitation he took out my front driveshaft. Now I have already replaced that darn sucker like twice, so I was pretty appalled when he took it out. Anyways, he took it out and pointed out that my car had one large ball bearing and many smaller ones and that I needed to change them to a "U Joint" type.. and that way the bearings won't ever come out of alignment and that my annoying shudder will go away. And well he told me that I should drive w/o my drive shaft.. so that I wouldn't damage anything. Now my 4x4 jeep is a RWD jeep. sucks because I have no Park. Anyhow, I was wondering if there was any truth to what he was saying and how much the whole thing would cost. Well thanks in advance...
EY
1995 GC 5.2 Limited V8
Green Jeep Club Member # 32
EYPUFF is offline
post #2 of 6 Old 06-02-2004, 11:55 AM
shelter1
I doubt that could be right???
Maybe the part about the u joint but it was made to run with a drive shaft.
Have you checked your steering stabilizer???
shelter1 is offline
post #3 of 6 Old 06-02-2004, 12:14 PM
greasefingers
greasefingers's Avatar
1994 ZJ
This is very confusing. My 94 ZJ with quadratrac has two u-joints, one at each end of the front drive shaft. Therefore I am assuming that the mechanic is suggesting that you to convert the CV-joints to U-joints
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #4 of 6 Old 06-02-2004, 12:44 PM
greasefingers
1994 ZJ
Sorry; after doing some reading in my book, I see that in 1995 used two different types of front drive-shafts. One with a CV joint at the front end of the driveshaft and one with a U-joint there.
Cheers Steve
post #5 of 6 Old 06-04-2004, 02:31 PM Thread Starter
EYPUFF
EYPUFF's Avatar
well i'm not too sure on what i've got. yes I know, i'm a newb. anyways, i'll take some pictures this weekend and yah, maybe you can help me out.
EYPUFF is offline
post #6 of 6 Old 06-04-2004, 03:49 PM
Meerkat
First off, that guy is an idiot. I wouldn't go near him on a bet.
Second, the only common problem ZJ driveshafts have is grease monkeys that think they know more than the engineers that designed your Jeep.
That being said, when the drive shaft is removed, it has to be replaced with exactly the same orientation as before, or you will get vibration. Has the vibration you had before at 70 mph gone away?
If so, most likely all you have to do is get your driveline balanced.
It sounds like you have the type 3 driveshaft (CV joints). There is a procedure for installing a CV drive shaft. So make sure whoever installs it next time knows what they are doing, or you are just going to continue to suffer vibration.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
WJ Drive Shafts JeepsOLot ZJ Grand Cherokee Forum 8 06-24-2014 04:13 PM
Explanation of How to convert drive shafts? 97ZJMAN242 ZJ Grand Cherokee Forum 3 01-25-2009 03:31 PM
Napa Drive Shafts swinterc ZJ Grand Cherokee Forum 1 12-21-2008 05:27 PM
drive shafts Casper4x4 ZJ Grand Cherokee Forum 7 08-05-2007 07:48 PM
swaping front drive shafts IronManVa ZJ Grand Cherokee Forum 29 06-22-2007 10:56 AM
