Question about CCW Waterpump - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Question about CCW Waterpump
TJ Dana 60 - BOLT IN REARSpartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEBds fox ipf 2.0 racing series shocks now available at rock
Unread 08-16-2012, 11:52 AM   #1
Darintbr549
Hi Mines not over heating and this might be the rong thred,but Im trying to find a water pump the set up to run counter clock wizes like the one I took off.
Ive even went to doge dealers. I have a 98 cherokee 5.2 with a serpantine belt. Evry pump Im show is set up to run clock wize. Any help any trhoughts a
part number?
Last edited by Darintbr549; 08-19-2012 at 11:27 AM.. Reason: Moved by Moderator to new thread.
Darintbr549 is offline   Reply With Quote
Unread 08-17-2012, 02:02 PM   #2
MGrobe
Man In Black
MGrobe's Avatar
bump
-Marc-
Sweet Pea 1998 - XJ
http://www.grobe.us/Jeep
- JeepForum Rules - Become a Premium Member or Vendor
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline   Reply With Quote
Unread 08-18-2012, 11:40 PM   #3
Darintbr549
Thanks for makeing this a new thred. I realy wished to have an anser. I dont want to ruin My engine. evry pump Ive seen turns wrong.
They suck My uper hose shut.
98 Grand Cherokee
Quadra Track
5.2
Stock tires
Unread 08-19-2012, 06:29 AM   #4
n5xl
Confused. The 89 shows to have a 2.5 or a 4.0 engine...there is no 5.2 engine.
NAPA show your application to have an integral water tube... Does it look like this?
counterclockwise
http://www.napaonline.com/Catalog/Ca...103_0131311192
clockwise
http://www.napaonline.com/Catalog/Ca...104_0131311190
Current Jeeps:
99 TJ
98 XJ
n5xl is offline   Reply With Quote
Unread 08-19-2012, 08:22 AM   #5
Saudade
1988 XJ Cherokee
There's no integral tube on the Renix. It's a separate threaded tube. AZ and a few other sites list pumps as CCW.
What do you mean by a 5.2 serpentine?
Saudade is offline   Reply With Quote
Unread 08-19-2012, 11:23 AM   #6
Darintbr549
counterclockwise
clockwise
Sorry Im dyslexica and reversed the nimers. Its a 98. Its a serpentine belt drive V8.
Thanks for the links proves there a difference.
Ive looked in alot of boxes with the wrong pump.
Thanks again for the links.
98 Grand Cherokee
Quadra Track
5.2
Stock tires
Unread 08-19-2012, 11:39 AM   #7
Darintbr549
Sorry I got the year rong its a 98 with a 5.2 in it I asked the queation in an other threed and when the Mod moved it They made the corect title for the year I put.
Ive trryed croses referancing with 5.2 Dodge pumps but every boxx was back words to. The all had the same pump on the inside as a V belt.
Even new Dealer ship looked up by vin was wrong.
98 Grand Cherokee
Quadra Track
5.2
Stock tires
Unread 08-19-2012, 11:53 AM   #8
Saudade
1988 XJ Cherokee
Well that explains it. You have a GRAND Cherokee. You're in the wrong forum. This is the XJ forum, you need the ZJ.
Unread 08-19-2012, 01:18 PM   #9
Darintbr549
Thanks I will send a pm to the mod that moved it to this section
98 Grand Cherokee
Quadra Track
5.2
Stock tires
Unread 08-19-2012, 01:37 PM   #10
Saudade
1988 XJ Cherokee
Good Luck!
I did check a few online websites and they all listed water pumps that run CCW.
Unread 08-19-2012, 05:04 PM   #11
Darintbr549
Good Luck!
Did any have pics of the impeler. I realy suck at web serches but the few I found that showed pic the impeler was wrong like mine is.
If You did could You please post the links?
be ezzyer sticking a 340 in I swear.
98 Grand Cherokee
Quadra Track
5.2
Stock tires
Unread 08-19-2012, 05:19 PM   #12
MGrobe
Man In Black
MGrobe's Avatar
Moved to ZJ section...
-Marc-
Sweet Pea 1998 - XJ
Unread 08-19-2012, 06:37 PM   #13
Darintbr549
Thank You Sir.
98 Grand Cherokee
Quadra Track
5.2
Stock tires
Unread 08-19-2012, 10:26 PM   #14
KoreaZJ
1994 ZJ
Check FlowKooler pumps... HERE
KoreaZJ is offline   Reply With Quote
Unread 08-20-2012, 10:53 AM   #15
ratmonkey
Living dead mod
ratmonkey's Avatar
ALL serpentine belt dodge pumps are "reverse" or CCW rotation.
the OLD (earlier than 92) dodge pumps for LA SERIES 318 motors with V-belt drives are all "normal" or clockwise rotation.
if you are looking in the right spot, they're impossible to miss.
i've only seen a few clockwise pumps go in because the box was mislabeled, someone put the wrong part back into it on a return, or the person buying it didn't know what they were after.
the correct pump will have an R stamped on the impeller. collapsing upper hoses is also a sign of bad hoses and plugged radiators.
ratmonkey is online now   Reply With Quote
