Question about A/C - JeepForum.com
post #1 of 11 Old 05-08-2004, 01:18 PM Thread Starter
the_oneills
Question about A/C
I have just installed a new evaporator and dryer in my 1994 Grand Cherokee 5.2, I have everything running but when I put the air on the Compresser dosn't come on and it used to. I have not put any Freon in yet. Do I have to put the Freon in or did I miss something puting it all back together.
Thanks for any help in advance,
Jim
the_oneills is offline
post #2 of 11 Old 05-08-2004, 04:39 PM
cfkingfish
cfkingfish's Avatar
If there is no Freon, then the Compressor will not spin. I believe that is the easiest way to determine when you are out of Freon .
-Christian
Christian
89 XJ 4.0 AW4
K&N 6x9 cone filter setup
Converted to TJ axles - 5-297 U-joints
Optima Red Top
Custom exhaust
www.ishopfaulkner.com
cfkingfish is offline
post #3 of 11 Old 05-08-2004, 05:11 PM
Meerkat
Jim
There is a pressure switch inside the compressor that will not allow it to run empty. It's designed to keep people that run their A/C's without freon or oil from burning the compressor up.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #4 of 11 Old 05-10-2004, 12:52 PM
liftedlimited13
i am a/c/ certified and what wvd said is exactly right. thats all. just go to wal-mart and get freon and the charging hose, dont waste your money on the kit that has the guages, you dont need that crap. just freyon and the hose.
liftedlimited13 is offline
post #5 of 11 Old 05-10-2004, 02:27 PM
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
I did just that the other night for under 15 dollars.
Hunter
04 4.7 HO, limited
08 Z71 Suburban, front leveling kit with rear spacers. 285/65 18s Nitto TerraGrappler G2s
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
602.841.3355
For your performance needs:
480.998.366
Texas ZJ1 is offline
post #6 of 11 Old 05-11-2004, 10:43 PM Thread Starter
the_oneills
Worked great thanks for the help one more dumb questions. Filled up A/C but having problem with the compresser staying on so I Jump wired the switch cumming out of the dryer and Air is Ice cold. If I plug it back in the Air dosn't work for crap. Compresser turns on for short time then of then on it's like a kid playing with a light switch. Is it bad to Jump wire it, I'm thinking of leaving it that way been working on this d??? A/C for about a week now. Any Idea?
Thanks in Advance again,
Jim
post #7 of 11 Old 05-12-2004, 03:04 AM
shadetree
is it that easy? my a/c don't pump out any cold air anymore but the fan still blows air into the cab. it just isn't cold. i was going to go to the dealer on payday but at $67+ an hour i'd like to save that money for future mods.
if anyone has a link or a direction for me to go in at making this a diy project then hook me up. i can go get the kit w/out the gauges and save a chunk of change then? with a '94 zj what type of freon does it take?
thanks in advance! my wife would be greatful too, since it's her dd.
"If I can't buy it or borrow it, I don't need it"
-1994 ZJ Lifted and Locked...
-1983 CJ7 4.2ltr/Dana 300/Warn F&R bumpers...and some other goodies.
D.W.A. (Death Wobble Anonymous)
shadetree is offline
post #8 of 11 Old 05-12-2004, 05:55 AM
Meerkat
Jim
Of course, it's not a good thing to circumvent any control circuit. The pressure cycling switch is used to prevent ice formation on the evaporator's core, this would obstruct air flow and cause system overheating, not a good thing.
The first thing to check is BAD PRESSURE CYCLING SWITCH AND CONNECTIONS. The pressure switch could have bad intermittent connections; also the terminals in the external connector may be corroded. The symptom was the a/c cycling on and off about three times per second. Television tuner cleaner (contact cleaner) and polishing the blade terminals on the switch could eliminate the problem.
Another common cause of short cycling is low freon (or 134a). Conversly, overfilling shouldn't cause short cycling, but will reduce cooling.
HTH
Warren
Meerkat is offline
post #9 of 11 Old 05-12-2004, 08:35 AM
unholy
the part of th process that i haven't seen anyone mention is...
Evacuating the system of all air and moisture before adding the new freon...
This is an important step after breaking open your system to replace components...
Go someplace and have the system evacuated. Then refill with freon. And if you don't have a gauge set it's going to be really hard to get the proper amount of freon in...
I find it hard to believe the certified a/c tech above didn't tell you this....
unholy is offline
post #10 of 11 Old 05-12-2004, 09:49 AM Thread Starter
the_oneills
Ok not good to jump wire switch so I'll work on it somemore. Could it be the information about have the system evacuated would do this, should I take it in, could that be my problem? I have a gage set I bought to put the Freon in what should it read for preasure mine reads around 35. Owner before says it's the Compresser that Pepboys tested it and said it was bad but it works when I jump wire it?
I will clean all termanals and post back. I will try to get a new switch that goes on the dryer if that dosn't work will post the outcome.
Weekend mechanic know enough to get into truouble and sometime enough to get out.
Thanks guy's
Jim
post #11 of 11 Old 05-12-2004, 01:03 PM
schaaed1
Jim -
I just filled my '98, and was observing the same on off symptoms you are. I tried filling it with one of the 'gauge kits' what I noticed was that when the compressor kicked in, the pressure dropped ... then it would cut out. Once the pressure rose again ... compressor went on and so on. Reading in the Haynes manual, it says that to correctly charge the system, the compressor needs to be running. Hmm, read a little farther and it says to jumper the switch like you did, to keep it running, then fill it. I put in 1 can, plus part of a second. The pressure leveled out (sorry don't remember the readings from the gauge) unjumped the connector and plugged it back in and life is good.
Mine system has not been apart (to the best of my knowledge) so I did not have to worry about evacuating it (did not even know you needed to).
Hope this helps,
Ed S
schaaed1 is offline
Newbiee Question?? - grand cherokee thumping question geoff6194 ZJ Grand Cherokee Forum 2 03-23-2011 01:59 PM
Radio code question - option question... GARover WK Grand Cherokee & XK Commander Forum 5 12-25-2009 10:39 PM
Question on Shock/bb combo... newb question craig10114 ZJ Grand Cherokee Forum 4 12-06-2008 01:04 PM
air condition face unit question n00b question Fatsooo ZJ Grand Cherokee Forum 4 09-21-2008 08:45 PM
couple minor questions. door question and mirror question Irish_Assassin ZJ Grand Cherokee Forum 2 07-04-2008 02:14 PM
