Question: 15" or 16" wheels on Stock WJ? - JeepForum.com
post #1 of 8 Old 11-05-2009, 09:24 AM Thread Starter
ivanfuzz
Hello,
I need some new wheels/tires for my stock 2000 WJ and I'm looking to put black Crager Soft 8s on it. My question is, since the stock wheel size is 16x7, should I get another set of 16x7s or should I do the 15x8? I want it to look more aggressive so I was thinking the smaller wheel would look better with those tires but unsure of the rubbing while turning with the 8 inch wheel. My plan is to put on BFG All Terrains (30 x 9.5R15) as the 15s are cheaper so I'm hoping the 15s would work.
If it helps, the Jeep is mostly driven on the road so I'm not worried about flexing on the trail.
Any advice is greatly appreciated.
Thanks.
ivanfuzz is offline
post #2 of 8 Old 11-05-2009, 09:44 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
you may need to clearance the brake calipers in front a hair for steel 15x8's, 4" backspace minimum.
ratmonkey is offline
post #3 of 8 Old 11-05-2009, 10:02 AM Thread Starter
ivanfuzz
Yeah, I didn't think about the brakes. I can get the 16x7s in the soft 8s...just sucks that the 16" ATs are $40 more more expensive per tire vs. the 15".
ivanfuzz is offline
post #4 of 8 Old 11-05-2009, 10:08 AM
GraKee99
Rapist Wit
GraKee99's Avatar
Get cragar soft 8s in the 15x7. They will fit. That is what I run.
Brian
WJ, WK, CJ5
GraKee99 is offline
post #5 of 8 Old 11-05-2009, 10:11 AM Thread Starter
ivanfuzz
Are you running the BFG MTs?
ivanfuzz is offline
post #6 of 8 Old 11-05-2009, 10:44 AM
the88thpianoman
2003 WJ
X2 on the 15x7. They will clear the calipers and you don't need an 8 inch wide wheel. My question to you is why swap out the wheels and get marginally larger tires on a stock height Jeep? Throw a cheap 2" budget boost on there and you can put a 31" tire under it.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #7 of 8 Old 11-05-2009, 01:58 PM Thread Starter
ivanfuzz
I really just want the new tires and a more aggressive look. The Jeep doesn't go offroading so it would be more overkill to spend a couple hundred bucks on a boost and then more for bigger tires.
Unless of course you know where I can get a cheap boost. I looked at Kevin's Offroad and TeraFlex but they appear to be around $250 or more shipped.
ivanfuzz is offline
post #8 of 8 Old 11-05-2009, 03:33 PM
biggoofy
look at rustys offroad
Zack
98 Slate Grey 5.9
96 ZJ HP44 / 9" (RIP)
90 XJ on 33s (sold)
biggoofy is offline
2.5" BB Kit with Stock 02 WJ "Avila" Wheels pajeep09 WJ Grand Cherokee Forum 15 04-01-2015 01:24 PM
WJ 33's on stock wheels with 4" Gamisou WJ Grand Cherokee Forum 12 08-23-2014 11:51 AM
Tires/Wheels question: Stock vs 3" lift w00t_Masta ZJ Grand Cherokee Forum 2 04-08-2009 10:04 AM
31x10.5 with 2" BB on stock wheels? ChvyKc ZJ Grand Cherokee Forum 8 04-06-2009 11:49 AM
will stock 15" xj wheels fit on the zj? bhanse4 ZJ Grand Cherokee Forum 2 06-22-2008 11:11 PM
