Quesiton from Sweden - JeepForum.com
post #1 of 16 Old 09-03-2004, 12:48 PM Thread Starter
swed40
First of all, please excuse my bad English !
This is a funny thing...
I will have a look at a Grand Cheroce model 1994
The funny thing is that the the car is imported from USA
2002, now the question...
Is there any big differens betwen USA and Europa model ?
Experts! wath is the most important thing to check before
the deal ? the car is in god shape, but i hope ther is some one
of you experts who like to help me further...
Best regards
from Swede
swed40 is offline
post #2 of 16 Old 09-03-2004, 07:24 PM
pgv98
1997 XJ Cherokee
check the vc in the transfer case (drive it in a figure eight after it has warmed up) if it binds it might mean you need a new vc which is expensive.
1997 Jeep XJ sport
4x4
150,000+
pgv98 is offline
post #3 of 16 Old 09-04-2004, 12:15 AM Thread Starter
swed40
Thanks, but wath is the "VC" and "if it binds" ?
Sometimes the English is to hard
But thanks for the replye
Best from Swede
swed40 is offline
post #4 of 16 Old 09-04-2004, 08:23 AM
Big Dumb White Guy
Big Dumb White Guy's Avatar
binding = crunching, grinding, it will NOT be smooth.
like a car - when you turn in a car it is smooth (feeling through the steering wheel). binding you would feel it in the steering wheel.
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #5 of 16 Old 09-04-2004, 08:37 AM
Meerkat
There are differences, yes. Though not necessarily big ones. For example, there is a headlight autoleveling feature on European models not available on US models. But for all practical intents and purposes, they are the same vehicles.
If the Jeep you are looking at has the Quadra-Trac transfer case (TC), the method it uses inside the transfer case to transmit power between the front and rear axles is called a viscous coupler (VC), which is similar to a clutch in that it allows slippage between the front and rear drivetrains. If the VC (in the TC) has been abused or subjected to sustained hard acceleration, it will lose it's ability to slip, so that when you turn the vehicle at low speeds (like in a parking lot), the front end will bind up or hop. It is an unmistakeable event caused by the tires hopping to release the power being sent to it by the damaged TC.
Sometimes the English is too hard for people in this country too.
Där de/vi/du/ni är differenserna , ja. Ändå inte nödvändigt stor en. För exempel , där er en strålkastaren autoleveling huvudnummer på Europeisk modellerna inte tillgänglig på OSS modellerna. Utom i realiteten syfte och avsikterna , de er den samma vagnen. Om den Jeep du er sett på har den Kvadranten - Spår flytta fall TC ), metoden den använda insida flyttningen fall till vidarebefordra förmåga emellan framsidan och föda upp hjulaxel är alarmerat en viskös koppling VC ), vilken är lik till en gripa i så pass den tillåt gled emellan framsidan och föda upp drivetrains. Om den VC ( inne om TC ) er blitt missbruk eller utsätta för till bäret hård accelerationen , den vilja förlora den er skicklighet till glida , så fakta ät när du vända vagn på låg farten ( lik i en parkering lott ), framsidan slut vilja binda upp eller hoppa. Den er en unmistakeable händelsen orsakat vid den tröttsam hopping till frige makten varelse sände till den vid den skadade TC. Ibland den Engelsk är alltför hård för folk i det landet alltför.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #6 of 16 Old 09-04-2004, 08:46 AM Thread Starter
swed40
THANK YOU !!!!!!!!
Thats funny, can you whrite Swedish or have you any off
this programs that translate ?
Funny thing anyway !
Thanks again
Best from Swede
swed40 is offline
post #7 of 16 Old 09-04-2004, 09:03 AM Thread Starter
swed40
Photo of my ( maybe ) jeep
Hi again !
By the way, could you tell me if this certan model has the
equipment that you whrite about, or could it be different from
car to car ?
It´s a 1994 Grand Cherokee
And for the record, nice to here wath they asking for
( price ) about 8500 USD
I think they are much cheaper in the States i guess ?
Best again
Swede
swed40 is offline
post #8 of 16 Old 09-04-2004, 10:10 AM
pgv98
1997 XJ Cherokee
Yes they are A LOT cheaper in the states. Check these sites for some information about the 1994 model
http://www.edmunds.com/used/1994/jee...t.num2.0.jeep*
http://www.nagca.com/nagca.htm
http://www.off-road.com/jeep/
1997 Jeep XJ sport
4x4
150,000+
pgv98 is offline
post #9 of 16 Old 09-04-2004, 10:47 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
Originally Posted by swed40
Hi again !
car to car ?
Welcome to the forum. If you go to this web site >
http://www.jeep.com/wccsapp/universa...ull&category=U
and provide the VIN (vehicle Identification Number). Ask for a build sheet. The build sheet will list all of the equipment and options on the jeep. You might have to provide a USA address to get this. Chrysler will email the build sheet to you.
If that link doesn't work try this one http://www.jeep.com/webselfservice/j...m%28%27R%27%29 and click on "send us an Email". Good Luck.
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
post #10 of 16 Old 09-04-2004, 11:01 AM Thread Starter
swed40
Thanks !
Hi my friends !
This is a nice forum, soo many helpfull people !!
The best regards from
Swede
swed40 is offline
post #11 of 16 Old 09-04-2004, 12:28 PM
Meerkat
THANK YOU !!!!!!!!
Thanks again
Best from Swede
Here is a link you will surely find interesting: Click here
JAG använda en online översättning applicering. JAG siffra emellan min Engelsk och översättningen mjukvaran , den Maj bli lättare för du till förstå.
HTH
Warren
Meerkat is offline
post #12 of 16 Old 09-04-2004, 02:55 PM Thread Starter
swed40
Thank you my friend !
Best from Swed
swed40 is offline
post #13 of 16 Old 09-07-2004, 06:04 AM
Big Dumb White Guy
check your Private Messages.
repost Nazi's suck!
post #14 of 16 Old 09-10-2004, 05:14 PM
LEDFoot
Damn, that translation utility you are using is a riot!
At least if you can read Swedish it is!
For those of you who can't (which I assume is all but me and Swed40) try to translate some text to swedish and then translate it back to english.
Tjena! Jag är också Svensk, bosatt I Kalifornien dock.
Jag köpte precis en 1999 Grand Cherokee Laredo.
Har bilen du kollar på blivit omgjort till Svensk standard? (Hastighetsmätare, tripp-mätare och allt det där).
I så fall så är det mycket troligt att antalet mil som visas på instrumentbrädan inte stämmer med hur långt den värkligen har körts. Det bör finnas dokumenterat från när bilen importerades hur många kilometer (eller miles) den hade körts då.
Vet du lite mer om precis vad det är för modell?
LEDFoot is offline
post #15 of 16 Old 09-10-2004, 07:26 PM
Meerkat
Oh I did that right away. And of course got some of the funniest phrases back
But I figure I had two things going for me, one: most people on here don't speak Swede, and two: bad as it might be, I bet it was easier for Swede40 to understand than my English!
Warren
Meerkat is offline
Quick quesiton about front axle RickyZJ ZJ Grand Cherokee Forum 2 02-07-2009 08:48 PM
