Quadra trac reliability? - JeepForum.com
post #1 of 6 Old 10-02-2003, 12:17 AM Thread Starter
greenman
Hi, I'm looking to buy a '94 GC w/ the 5.2/Quadratrac w/ 120K. From what I know the Chrysler 5.2 is a pretty reliable engine, but I'm not sure about the Quadra trac. How many miles can I expect from this tranny? The tranny drives fine now. As soon as I get it I'm going to change all fluids and the chain. And what's the first thing to go on this tranny? Anything else to watch out for on this model year?
greenman is offline
post #2 of 6 Old 10-02-2003, 05:53 AM
Harald
Got a 96 (same set up). Advice: Change oils, don't mess with the rest if it functions OK. My old Jeep has run for 200K with no tranny problems. First thing to fail will probably be the VC. Or do any other have better suggestions?
Harald is offline
post #3 of 6 Old 10-02-2003, 07:47 AM
jeepme79
Other than normal maintenance, the biggest thing to be concerned with would be the VC. Keep the tires rotated and a the same preasure on a regular basis. This should help it last longer.
2003 Dodge CTD Quad Cab 4x4, 320k miles and counting
Former Jeeps:
98 ZJ Limited, 5.2L, NP242, Jet Stage II (worthless), K&N, 245/75-16 BFG KO's
89 XJ, stock
79 CJ7 - Options included ripped soft top, leaky 4.2L (5qts/week), ripped seats, 33" tires, bondo & gray primer
jeepme79 is offline
post #4 of 6 Old 10-02-2003, 11:37 AM
iroc22
iroc22's Avatar
You dont have to worry bout the tranny; it's almost bulletproof. I've found either the VC or the 249 chain tends to go.
2002 Jeep TJ Sport 4.0L Patriot Blue/Black Hardtop Dana 44
1996 Jeep ZJ Orvis fully loaded
1995 Pontiac Trans Am 5.7L - 6 speed
1928 Ford Model A - Street Rod Project
iroc22 is offline
post #5 of 6 Old 10-02-2003, 03:18 PM Thread Starter
greenman
so anything else on this model I should watch out for?
greenman is offline
post #6 of 6 Old 10-02-2003, 07:36 PM
Ryan45
I have the same jeep. I got 124,000 on it and it's still going strong The only thing that went out was the Transfer case witch was at 80,000.
94 Grand Cherokee 5.2 V8
Ryan45 is offline
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 04:45 PM
quadra drive II or quadra trac II 2008 WK ? bill.rivard WK Grand Cherokee & XK Commander Forum 12 06-16-2009 07:14 AM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 04:52 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 01:21 PM
Difference between quadra trac and quadra trac II? loudog3114 ZJ Grand Cherokee Forum 1 10-10-2005 12:07 PM
