quadra-drive not working - JeepForum.com
post #1 of 13 Old 04-03-2008, 12:20 AM Thread Starter
clintgoldstein
I just bought my Jeep a few months ago. Its a 2000 grand cherokee with quadra drive. I noticed right away it had worse traction in snow and ice than my civic. (unless I put it in 4-Low). So I had a friend watch as I put in on some ice and then some mud and purposely lost traction. I wanted to see if the quadra drive was sending power to the front wheels like it was supposed to. My buddy said when I made the tires spin out the front wheels weren't spinning at all, It was just rear wheel drive. The 4-low works at least and I can use that if I get stuck. However it sucks the all-time 4 wheel drive "quadra-drive" doesn't work because now I don't have a 4-hi. Any ideas on whats going on?
clintgoldstein is offline
post #2 of 13 Old 04-03-2008, 01:08 AM
MGrobe
Man In Black
MGrobe's Avatar
Relocating to the correct forum...
-Marc-
Sweet Pea 1998 - XJ
For Sale: (4) AR 767-5766 Wheels (used) 15x7, 5x4.5, 4.5BS - for local pickup in the Chicago-area
MGrobe is offline
post #3 of 13 Old 04-03-2008, 04:50 AM
driabyor
driabyor's Avatar
1994 ZJ
change oil in transfer case. i think it uses a Jeep dealer only fluid.....
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline
post #4 of 13 Old 04-03-2008, 05:47 AM
skain8
skain8's Avatar
^^ that would be my first step. You must use the proper fluid in the transfer case for QD to work properly.
'02 WJ: 4.7L, 5", HP44/9", 231HD, tall & skinny KM2's
skain8 is offline
post #5 of 13 Old 04-03-2008, 05:54 AM
Turbonut
QuadraDrive is only the addition of VariLok diffs front and rear. The transfer case which is responsible for transmitting power to the front, is the same as the QuadraTracII, 247 T/C.
As stated above, get 2 qts. of the 247 fluid from the dealer, drain and refill and give it a try.
The Jeep will work in 4 wheel low as the front and rear shafts are locked together.
Turbonut is offline
post #6 of 13 Old 04-03-2008, 09:36 AM
doggboy
The 247 fluid from the dealer is actualy mobilfluid 424 which is a tractor hydrolic oil. I run amsoil ATH http://www.amsoil.com/storefront/ath.aspx because I absolutely refuse to buy anything from the stealership I don't have to. My dealer wanted 18 bucks a qt for the 247 juice, amsoil is only 7.45. The mobilfluid is only sold in large buckets that cost like 50 bucks, but if you have a tractor shop around you, I bet you could get some pretty cheap.
doggboy is offline
post #7 of 13 Old 04-03-2008, 09:50 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Try changing the fluid, however I am willing to bet the PC (Progressive Coupler) in your TC (Transfer case) is shot.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #8 of 13 Old 04-03-2008, 10:14 AM Thread Starter
clintgoldstein
Thanks everyone for your replies. I appreciate it alot.
If it is the PC, is that a lot of money to fix?
Also, can I change the fluid myself?
post #9 of 13 Old 04-03-2008, 10:25 AM
LEDFoot
Changing the fluid is very very easy. Make sure to get "NV247 Transfer Case Lubricant" from the dealer.
Oh, and make sure you're able to get the fill plug open before you open the drain plug on the t-case.
If the PC is shot yes it will be expensive. You have a couple of different options:
1) Rebuild your TC (expensive and not easy to find parts).
2) Find a used 247 and replace it with (but then it's hard to know the condition of the used unit).
3) Find a used NV242 TC and put that in instead. This is a popular option since a 242 can be found much cheaper than a 247. You do however need some more parts like the rear drive shaft and a new shift console if you want the transfer case modes to be labeled correctly.
--Martin
_____________________________________
'99 WJ 4.7 Quadra-Drive w/ 242HD swap... 2WD since my front diff is kaputt :(.
LEDFoot is offline
post #10 of 13 Old 04-03-2008, 10:38 AM Thread Starter
clintgoldstein
Well thanks again for the help. I went over the maintenance logs from the people that sold it to me and it said they had to fix a leaky transfer case once before so I'm hoping thats it.
If it is the PC I simply dont have the means to fix it. I'll just use it as RWD and shift into 4-lo when stuck. If I have to do this will it damage the car in any other ways? In other words is this something I have to fix?
post #11 of 13 Old 04-03-2008, 10:51 AM
ArloGuthroJeep
Mr. Hyde!
No damage in doing that, at least no more then is already present.
For the PC you can either find a replacement PC online, probably $400 ish for one plus installing it (removing the TC, opening it up, replacing, and then reinstalling. Or you could find a junkyard TC (quite a bit cheaper - $100ish probably).
post #12 of 13 Old 04-03-2008, 11:16 AM
Envygreen
If the move was made to the 242 what becomes of the vari-lok system does it still work as designed when engaged in 4 hi or do you replace the diffs too?
Envygreen is offline
post #13 of 13 Old 04-03-2008, 11:18 AM
ArloGuthroJeep
Mr. Hyde!
They are independent...everything works as normal still.
is quadra trac/quadra drive electronically controlled? dirtdad ZJ Grand Cherokee Forum 2 01-01-2010 04:45 PM
quadra drive II or quadra trac II 2008 ZJ ? bill.rivard WK Grand Cherokee & XK Commander Forum 3 11-01-2008 04:52 PM
quadra-drive...is it working??? tcris3 ZJ Grand Cherokee Forum 16 02-11-2008 03:43 AM
Quadra-drive quit working srode ZJ Grand Cherokee Forum 4 12-28-2007 08:16 PM
Possible Quadra-drive/Quadra-trac II binding problems orbornhitorn ZJ Grand Cherokee Forum 3 06-06-2007 01:21 PM
